alicemywonderland
- Feb 23, 2016
Bro Gixxer.... once we have appt date, is it still possible will change by HDB?
I means if ppl in front my number give up the appt.
whoa until 24th may? 24th may pay OTP fee liao. they also no choice got to let us see. hahaha.
im fine with or without actually. those high floors one mostly without flooring. Senja gateway looks great from the outside, but mostly without flooring too![]()
You?
Appt 31 May, what is your area and roughly how is your number?
thx
Punggol, Q no 2, 4 roomer.
Do u guys know how long will the selection process take? Hours?
thank...
wow... punggol 4 rooms total 196, u no.2 and appt 31 May.
then if sembawang Q no. <50 should mid-end of June....
am I right guessing?
Hi all. My hle is expiring on june. But my flat selection on 26 may. Any idea whether i will get the key earlier? Or they dont need the hle when i coolect keys?
They will automatically extend it usually..
If they need u to reassess, they will inform you.
Hmmm. But got once i called. They say now when collect keys, they dont need the hle. But some people say will collect the eys earlier instead. Because im self employed. And did not keep bank statement for these months. And i reconfirmed witht the staff.. if they really reaccess... then $100+ gone.. haiz
Is the unit u're looking at with ready keys?
Ready keys unit usually they will extend HLE..
Even if you select on 26th May, it's just selection, not signing of lease agreement or key collection..
Sorry. I meant that if i chose a flat which is completed and with ready keys. Thank you for your help on this!
if you have already selected the units that you favoured (bookmarked), it should be fast, especially since you are on the early number. Prepared all the docs and filled out the forms beforehand it'll help a lot in the processing time.Punggol, Q no 2, 4 roomer.
Most likely getting with flooring but seems like senja gateway flooring got problem. I think there 2 units high floor with flooring at senja gateway...
Sorry can't reply your PM. not enough posts to use the PM function. Need another 2 more! lol
