Proposal Ring - Part 3
Big Dan
Dear all,
Here are the scope images. As I spent quite a lot on this diamond, would like to know if I made a good choice for my diamond. Please kindly advise! (Can a kind soul help me post my pictures please? Insufficient post counts :()
>>>postimg.org/image/47njybnlt/<<<
>>>postimg.org/image/6kt368cox/<<<
>>>postimg.org/image/ipr6pk01t/<<<
>>>postimg.org/image/wcp0wkpq9/<<<
>>>postimg.org/image/myeyif135/<<<
spLeenfuL
Dear all,
Here :)
I can't upload the certificate for some reason.. maybe other bros can help with that.
Scopes looks good! Definitely a Super Ideal quality. very nice and *ahem* big hoot :)
dearmisterj
Dear all,
Agree the scopes look very nice.. but like I said you may want to go ask them about the incursions at the side because that would be my concern if I were you.. dont worry the JP people are very frank and open with such queries :)
peanutbutter1990
Hi guys! Finally made a trip down to JP. Any comments on this diamond? AGS 104079881048, 0.604ct.
dearmisterj
Not yet. Still waiting for them to send it to me. Will share it when I get them. Thanks!
Sure :) I doubt there will be much issues though the octagon is a signature cut of JP's. Just be sure to check the incursions to your satisfaction so that you know what you are paying for. I'm getting an octagon myself too ;)
fir3bon3
appreciate any comments on my scope images below, thanks!!
Hey Cookie bro~ there you go, your scope images.
They look good to me, all displays maximum light return so don't worry.
You chosen your ring design yet? Or doing some customization? :D
lesnarchen
Needed help on my new reserve
hi all,
i have just gotten my scope images from JP for a 0.524, E VS1 Solasfera
AGS 104084369032
i need help from u guys to advise if it is a good buy based on the scope images.
>>http://i.imgur.com/eWSNVhx.jpg<<
>>http://i.imgur.com/Mk8defz.jpg<<
>>http://i.imgur.com/dKYoeIn.jpg<<
>>http://i.imgur.com/Xaffbb8.jpg<<
can someone pls help me to post the images? appreciate your help!
thank you!!
spLeenfuL
hi all,
AGS 104084369032
thank you!!
Uploaded!
If you compare to to the other higher facets diamond in the market, the Solasfera is a v good buy :)
donlaughla
Dear all,
I am deciding between the following 2 diamond:
- 0.54 E Colour $4250
- 0.606 E Coliur $5400
The price difference is about 1.2k but the size of the carat is mere difference.
Any advise from you guys?
DiCaprio
Dear all,
Clarity specs the same? For the price I'm assuming around VS1. Personally, I think upgrades in carat should be at least 0.1 carat. If not the incremental difference is not worth the extra $. If your gf is petite to average ring size, a 0.54 should suffice.
Sent from the dark side of the moon using GAGT
fir3bon3
Dear all,
I personally will go for the 0.606 E diamond. I can see the diff between 0.5ct vs 0.6ct thats why I will choose 0.606ct. It really depends whether is it justifiable for you to pay the 1.2k for the jump to 0.606.
What is the clarity grade for both the diamonds?
donlaughla
Below are the scope images for the 2 diamonds, need the advice from you guys :)
AGS 0.606 E Colour VS1
>>http://imgur.com/CpPnAQs<<
>>http://imgur.com/0YuqLxj<<
>>http://imgur.com/0mQi3ip<<
>>http://imgur.com/5FtA6fa<<
GIA 0.54 E Colour VS1
>>http://imgur.com/UyZl9nA<<
>>http://imgur.com/zM1osod<<
>>http://imgur.com/g28u6Vf<<
>>http://imgur.com/2qqoFCb<<
Thank you
lesnarchen
Uploaded!
thanks bro for the help! i am considering between getting this Solasfera or a Super Ideal (my gf says she don't really fancy a 'disco-ball') lol. so may go for a Super Ideal 0.56 E VS1. price wise, it's about 600 reduction. VS Solasfera 0.524 E VS1
dearmisterj
Can consider an octagon, not the typical round diamond and yet not as 'disco ball like' as the solesfera ;)
