LG G3
allanzzz
Just clear all data reinstall?
This should at least clear the crash messages.
Next step should be change battery, my phone reboot like crazy after 6 months, but new battery is still ok after one year.
Sent from LGE LG-D855 using GAGT
Joelleyuan
Mine was stock sg with root.
I think I saw 460 here before.
http://lg-phone-firmware.com/
Btw do you have lte advances in sg?
i think LTE should work.
but the problem with F460s is i can't find a suitable rom for it in XDA....
spent one whole afternoon browsing thru threads, most rom are not for F460S,
one or two are, but kinda old, and got bugs.... so....:s22:
am just thinking of rooting it to get superuser access and delete the camera sound nia. :s8::s22:
Emospence
It doesn't just reboot, it also freezes and got the kernel crash message sometimes, doubt it's battery.. Factory reset didn't work
allanzzz
Delete of the sound file does not work. In both lollipop and mm, I know it sounds weird....
Joelleyuan
Yes, tested, does not work.
Delete at the media then ui or sounds folder right.
I root and install xcam to get rid of shutter, still works pretty good but got sound for tap to focus.
delete the file already still got sound, so where does the sound come from?
this is crazy....
i need it to be quiet for work purpose.
thanks for telling.
zenify.me
this is crazy....
thanks for telling.
Easier solution may be to use 3rd party camera app.
Running MM v30f on my D885 just required me to change it to silent mode and the shutter sound is gone.
Xtreme_Funktions
my G3 keep losing telecom signal. is it dying?
only experience this since 2 days back where it wasn't so serious..
didn't root my phone btw. tried to last time but it couldn't..
Intrinion
Senior Moderator
Senior Moderator
Could be due to this:
Dear customer, please note that we will be performing a system upgrade on 26-05-2016 (01:00am to 04:00am SG time) to serve you better. During this time, local and roaming data services will be unavailable. We would like to apologise for any inconvenience caused and will strive to keep the downtime to a minimum.
Do reboot your phone and see if the problem persists. :)
roytanlk
I faced similar problem and found the solution at
http://forum.xda-developers.com/lg-g3/help/sim-card-t2826785/page2
"It seems as if a pin or two weren't making contact with the sim card. After putting a little piece of 3M tape on the sim card, it created enough contact and all is well."
I tried it and works. Hope this helps.
thanks i had reboot my phone yesterday which drive me mad. i even reset to factory and though the issue was gone until hours later it appear! :s22:
anyway, today so far seems to be ok.. pray it stay this way.. :s12::s12:
Intrinion
Senior Moderator
Senior Moderator
Any more issues? :)
ahtea
Just got a used G3 as spare phone and reformatted and turned off all the battery hungry features like gesture etc even turned off sync. The battery life is terrible. Fully charged just use for awhile it gets hot at the back. Drop 1% like every 2 mins.
Left overnight on flight mode but with wifi on for about 8 hours it dropped 20%.
Is that normal or should I get another battery?
It's still on lollipop btw, thinking of manually flash to MM tonight.
I think it might be some background apps running without your knowledge. Mine takes 2% an hour if i leave it there without much activities.
If i do Facebook, battery drain is about 2% per 5-10mins.
Shdwfalcon
