Air conditioning - Any recommendations please??
xman13
Xman, I was quoted 3k from Daikin Alexandra for system 3 but they exclude cabling. They have free site visit if u confirm with them. Otherwise, u gotta pay $50 for it. My friend confirmed with them but installation only in June. I will see if it's good then decide if to get from them.
I prefer to get them to do all. why not include cabling, its abit weird.
xman13
Parisilk and Court i wont go to them for aircon. I think they will get subcontractor to install for you. Might as well go directly to subcon?
Wait Parisilk squeezed the subcon the subcon squeeze u on material how?
Where do you suggest I get it from? Daikin directly? I am leaning to this DAIKIN SILVER ENVI SYSTEM 3 ( 2X FTKJ25NVM +1 X FTKJ42NVM).
Any recommendation will be great. I using the same casing. but cabling and piping I think better use new as mine is more than 5 years old.
maur_james
That's the question. That's why I nvr on them. It's like getting them to install a toilet bowl and then they say it don't come with seat cover :)
Haha...maybe a closer analogy would be fixing toilet without connecting water supply or don't provide water piping.
xman13
They provide water piping and got connect water supply. Only thing they don't include the flush button :) :) :)
Just went over during Lunch, Daikin proshop(Fortuna), just clarify, includes all wiring and cabling, dont have to source to buy anything. Quoted DAIKIN SILVER ENVI SYSTEM 3 ( 2X FTKJ25NVM +1 X FTKJ42NVM) -$4980 +150 for bracket.
2 x FTKS25DVM (9K BTU) and 1 x FTKS50FVM (18K BTU)-$3450 (Inclusive of bracket... warranty 2+1 +90days(if buy at proshop). Any feedback on FTKS25DVM ?
Hottyhot
Walau eh..... Then why the lady quote me 3k for the system 3 (3MKS71) for $3k without cabling... She even say their package don't cover cabling... Wonder is it becos yours higher end so include cable or she see me honest face so try to exclude the cable
wwh5210
All most all the vendors quote me "FTKS25DVM" fan-coil model. I have seen the actual set and it looks fine but a bit shorter as compared with others.
maur_james
That fancoil is their basic 'tan jiak' unit so should be no problem, else you will hear or read about complains everywhere.
deathdealer
the 28VA is referring to the fcu or the external unit?
all the MXY external units. google for renotalk starmex.
some one mentioned the PCB have problem in this thread back in nov 2015 as well.
those forumers who changed their mainboard or controller boards, fan motor etc please post here and spread awareness
lingcw
MHI System 2 with CoolServe
Finally took the plunge and place order with Coolserve for a MHI system 2.
Installation will be on 9th June. Will see how it goes.
Wanted to go for 9000BTU as both the rooms are about 150 square feet each. But according to Coolserve, the distributor of MHI has no stock of 9000BTU hence the current promo for free upgrade to 12000BTU.
Also upgraded the insulation to 1/2" armaflex class-1 but kept the copper pipe at 23 SWG due to budget constraint.
Generally their price is on the higher side, only Gain City is more expensive than them. But their optional like bracket and insulation/copper pipe upgrade is more expensive than Gain City.
So overall, Coolserve and GC's prices are about the same.
Decided to go with CoolServe as my friend uses them and said good things.
Will see how the installation goes. Hopefully I made the right choice.
*fingers crossed*
ksrokiller
*fingers crossed*
Do take some pictures too=)
Hottyhot
*fingers crossed*
How much u paid for it? Does it includes cables? :)
DarthGW
i read that the new 5-ticks starmex is noisier and the cost savings only achievable not in the first year if you dont use it 8hrs everyday.
any feedbacks?
i am torn between ME and MHI.
current family house using MHI no problems, so thinking if i should change for my BTO:s22:
gld998
any feedbacks?
:s13::s13::s13:.. I dumped Mistsubishi products and have gone for Daikin. Using for 2 years no problem so far. ** StarMex and heavy industry same pattern everyday. :(
meowkat
did a quotation request via email..3days back
only cool engine replied as follows:
Daikin inverter System 3 - $2920
3MKS71FSG/FTKS25DVM/FTKS25DVM/FTKS25DVM
Mitsubishi Starmex System 3 - $2860
MXY3A28/MSYGE10/MSYGE10/MSYGE10
** Note: Above price is for 1 storey HDB/BTO
Stardard piping materials without upgrade
1. 16mm pvc drainage pipe with 1/4 inch thickness armaflex insulation.
2. 23g copper pipe with 1/2 inch thickness Class “1” armaflex insulation.
3. Keystone/Sigma 3 core 40 & 70 wire.
4. Stainless steel bracket is additional $150 nett with installation if necessary.
5. Total piping length for system 3 is 45 meter (Over length will be charge $8 per meter, max charge up to 15 meter)
Warranty
1. Compressor 5 year (Dealer warranty)
2. Other parts 1 year for Mitsubishi (Dealer warranty)
Other parts 1+2 years for Daikin (Dealer warranty) - Purchase by 18/6/2016
3. Workmanship 2 year (Installer warranty)
1st year to 2nd year will be warranty piping and wiring but not included insulation sweating.
Insulation only warranty for 1st year.
May 2016 Package
** Free Site Survey
** Free 2 trip installation
** Free upgrade to G22 copper pipe (Thickness and Hardness gas piping)
** Free upgrade to Class “O” half inch Armaflex Insulation. (Fire protection quality)
** Free Unlimited piping length (For BTO only)
** Free dimantle and disposal old set aircon
** One time ac-hoc general servicing with special rate for no units of install within 1 year- $15 per unit.
** One time ac-hoc chemical overhaul with special rate for no units of install within 2 year- 30% discount
per unit (Price different base on BTU)
** No hidden cost (Nett Price)
** Promotion while stock last.
** $100 deposit payment upon job confirmation.$900 payment upon piping installation. Rest of payment is
COD upon completion of job (Cash or cheque payment acceptable)
Michelle Soon - Cold Engine Air-Conditioning Service/Cold Engine Engineering Pte Ltd
Tel: 65 63620363 Fax: 65 63622032
still tinking to get from who now
if.. Proshop alexandra does not provide cabling and is already at 3k.
Hottyhot
Warranty
May 2016 Package
** Free Site Survey
Proshop giving additional 3months warranty. Seems cold engine price quite good leh...if include the free upgrade, then specs will be the same as Proshop but better deal from cold engine since it is $80 cheaper and include cabling
