So.. managed to get my hands on EBL taste Matte Clay. Shoutout to bro gaoxing84 who very kindly passed me his unfinished tub
Tried it out today for the first time, so quick review.
Cut to the chase, the texture of the product is your typical dry clay. It feels rough at first, but is surprisingly easy to emulsify on your palms. Going in, it doesn't tug or pull too much on the hair, so application is fairly easy.
Let's get on to the hold. This is one of those products in which you can feel the hold instantaneously upon application. It's damn bloody strong. I made the mistake of putting in too much product today, so honestly I think all you need is a little bit. Putting in too much of this product is most likely gonna weigh your hair down so do experiment with the amount that your hairstyle/hair type can take.
Finish wise, you get a decent matte finish with some nice texture. There might be a little bit of a shine if you apply too much product though.
Washability I can't say now, as I have yet to shampoo my hair. But I feel like I could get most of the product out by rinsing thoroughly with water. Based on my experience though, this should shampoo out in one go. Will edit and update once I have shampooed.
All in all, a product that is definitely on par with some, if not most of the clays that I've tried thus far. (I've tried most of the big names, trust me ) Bro DJ_Flame did compare it to By Vilain's Dynamite Clay, and I can now see why. Those looking to try out a decent clay product but don't want to spend as much, this is your thing right here.
