ZTE Axon 7
Chevalier
a very intriguing and compelling device. I wonder if the software updates will be prompt
White Shader13
Hey guys does anyone know if the US version 2017U will be compatible with the 4G bands in Singapore? They list FDD-LTE B1/B3/B7 but not in numerical order??. IF my understanding is correct, it means it should work?
On the flip side, would SG's version (assuming the global model 2017G) be considered inferior in terms of the bands supported according to the specs?
US version is ZTE A2017U
It has the following bands and this model is specifically for the US market:
GSM/EDGE:B2/3/5/8
CDMA BC0/1/10
UMTS/HSPA: B2/B5/B4/B1/B8
LTE: B2/B4/B5/B12/B13/B17/B7/B3/B1/B20/B29/B30/B25/B26/B41
2CA: B2+B4, B2/4+B12, B2/4+B29, B2/4+B5, B41+B41, B25+B25
Won't work in China? Super confused with these bands :s11:
chiaRH
GSM/EDGE:B2/3/5/8
CDMA BC0/1/10
I think it should work? Ours are bands 3 and 7 indeed
https://www.frequencycheck.com/compatibility/Ar54E/zte-axon-7-a2017-dual-sim-td-lte-64gb/countries
BERSERK1980
Quite keen on this model. Its released overseas liao. Any lobang to get export set now?
