Xiaomi Mi Max
raptorized
Where do you guys get your tempered glass protectors? Some of the reviews I see on qoo10 are quite bad
maxlovely
The set is reseal by reseller after they break the original seal to install playstore.
If you observe carefully, you will notice the seal you have is different from original seal.
You can search on YouTube to see how ppl use hotair gun to do the seal.
Received mine yesterday. Sealed package.
Haven set up it yet but I have switched it on and I noticed that playstore is showing on my screen. Is it normal?
I thought china ROM will not have playstore?
ckboyz
i see! i think they helped me installed for free then lol... because i didnt pay the extra $5 for that installation service
CrucifyMyLove
i feel tat those who charge $ for installation of playstore is despicable :mad:
DaRRenLieW
Continue to amazing me !
After one whole day of usage total time on 17hour + and sot 8hour with 30% left.
Speechles!
nomoney25
I don't know if this is normal for China ROM Xiaomi phones or not but ....
When there is an update available like Whatsapp, why does the phone always go Mi App Store to update itself instead of Google Playstore?
The reaction is the same when i try to download some new themes for my Amber Weather Widget. It goes into Mi App Store to locate the themes, and never to Google Playstore .... which means i can never download any new themes :s22:
I feel your frustration coz I owned a China Redmi note 2 and I sold it off too. Sg local note 2 does not have this MI App Store install and work perfectly with Google play store. Maybe someone who is expert of rooting the phone can help on it.
maxlovely
You could have install the global rom on your Redmi note 2. Problem solved.
mar5000
Maybe you can try turn off everything from setting->system apps->app store.
nomoney25
May I know It is easy to install global ROM? Any risk of brick the phone? That why I waiting for official sg version.
As i am the kind of user who just charged and use and don't go into customize and rooting the phone.
cscs3
Just uninstall the MI App store if your primary application is with Google play store.
Remember China rom version is not suppose to have Google play store.
nomoney25
Yes. My Xiaomi note phone was bought from China. No way I could Uninstall the Mi App Store.
Lamwm
Uninstall mi app store
You can't install mi app without rooting. It is a system app.
Furthermore if you manage to uninstall it, you will probably get a bootloop.
Therefore it is wiser to freeze it with titanium backup after you root instead of uninstalling.
