Aztech DSL7002GRV-(s)
Strikk
may i ask have u change any settings to ur pc or router b4?
Nope, I didnt change any setting at all. Not familar with network terms and stuff, assemble computer still okay but network stuff abit out of my depth.
I was on 200mbps until during IT show weekend when I upgraded to 500mbps online. My service went down on 0000 5th May for a minute and I went to check on speedtest and it shows 350mbps download, 500+upload.
ZrE0_Cha0s
wait so u tested on a pc with lan cable or pc with wifi or phone on wifi?
ZrE0_Cha0s
have u tried restarting ur ont and ur router? switch off router, den ont and wait for 10 sec, on ont, wait for 10~15 sec, ont router to test it?
Strikk
Ill try tonight! I only off router before, will do the ont tonight. Thanks ya!
Strikk
Did the on off router and ont today and my speed is still the same, 350mbps download on speedtest.
Any ideas? Change cable? Upgrade software ?
ZrE0_Cha0s
only cable change, software we cant upgrade on our own, only singtel can upgrade.
renfred89
try resetting the aztech router and see if it works?
if not you might wanna try it on a different pc if possible?
Strikk
When you say reset you mean go to the homepage and find the reset option? or on off the router?
Strikk
Still 350 to 400 from speedtest.
Probably ill change the cable. Should I change to Cat 6a or cat 7?
renfred89
if u too rich lor.
i'm using valore cheapo cat 6 cable and is super performing well.
so how much u intend to spend on a cable? :D
ZrE0_Cha0s
I just want the speed I paid for lols. 50 bucks can get good quality one?
but u still need to think of the distances as well. but im not sure 50 bucks can get u long enough to your room from the router.
Strikk
The fibre point is inside my room. So no problem. Direct connection less than 10metre.
ZrE0_Cha0s
ah i see, yup should be fine for that $50 dollar cables, but u dun go ask the prices 1st just ask for a distances and the category and see how much it cost.
Strikk
Singtel got back to me with a Pinoy CSO. He keep insisting that its normal for me to get 350mbps download and 500mbps upload citing "different speedtest portal" will give different result.
He ask me to open Youtube HD video and to see if i can load vid3o. Which doesnt make sense, Im on fibre of course it will load fast but Im still not within the advertised range of download rate.
I asked him then which speedtest website singtel recommend? Ill do the test there and show you the result. He say singtel dont recommend any speedtest portal. Waste time only, got a feeling their SOP is to blame the user and speedtest portal.
