lmf2501
- Sep 25, 2006
Check qoo10. I ordered my casing from there yesterday.
which type n color? share link can?
Anyone knows where to get full tempered glass for mi max? The one I bought doesn't cover the screen completely cause of the curved edge
Sent from Xiaomi using GAGT
Thanks!all teh SP so far are like that , not sure local have full coverage yet.
I am using a samsung note 5 fast charger with a charging display. It shows 5.1V at 2.1A.. works out to be 10++W
On note 5 it charges at 9V 1.8A.. nearly 17W..
So.. no fast charging happening for me
Using Mi Max 64GB fyi
that's what i understand too.I think why Xiaomi didn't enable or if they have but didn't advertise it is because prolong quick charging will shorten the life span of the battery and overheating may occur.
Sent from my Rice phone using GAGT
jut got my mi max.. when installin apps via mobile data, thers no issue but when thru wifi, although it shws wifi connected but at play store, it shws "chk ur connection and try again".. anyone encounter tis
Yes, when I first collected the phone
Check Google play permissions, set Google app to auto start and reboot
Hardly one own of it. How to compare.??Compare with Nubia z11 Max, which is better
thanks for reply, but where to chk permissions, set to auto and reboot?
Where to get? Any pics how it looks? Never tried before.get the healing shield type ba
covers whole screen with no halo effects
Can u share some pics please? Where did u get itFull coverage tempered glass are those with color frame.I using one gold frame with no halo effect.
