garychengjw
- Jul 18, 2010
Tempted to try. Use phone mainly for work, talk, email and surf net. Watch video and read on my tablet but may change with this
Questions for current users:
- ROM stable?
- Battery life ok?
- Any drop call, wifi connection and 4G network problems?
- Seems like different variation from different sources, I just need basic model. 32gb good enough?
Thanks
wah falcom bro u quit lg camp ah ?When will the 4GB version be available at the local phone shops?
Maybe have to wait long long.
Any brothers can enlighten?
Miui is out of question. Never a stable version.
Its stable as long as you use global stable rom.. Many use bina dev rom for new features and version which is usually not stableOh my? How unstable is miui? how often will hang/reset?
Prefer stability instead of latest and best![]()
Aiyah buy from lazada mobile.bee $316,apply standard charted card $30discount code only $286 inclusive delivery
Sent from Xiaomi MI 5 using GAGT
Just tested mi max on Aukey pa-t15 Qualcomm QC 3.0 charger, can charge up to 15.1W according to the watt meter display from 24% onwards.. it's higher than what the xiaomi 5V 2A charger can provide.. (10W). My mi max variant is 32gb variant
I am on Global rom for Mi4i and Note 2. On average, I would have to reboot the phone once a week. For Mi4i, it gets auto reboot if I do not do it.
Global rom not available for max yet. Maybe unofficial does.there are so much talk on Global rom? am just wonder,
where to get this? is that easy to install? layman like me can do it or need special skills to do it?
any advise?
Reboot cause it hangs or just to clean it up? How to now if seller provides global rom onboard phone? If not, possible to DIY and boot global rom on phone.
Thanks
The Mi4i is a disappointing device. That lag..
