the ONEPLUS 3
batboyz
but last time I bought opo also us set so far no problem with the lte band
Last time US set OP2 got LTE band 3 and 7, but this time OP3 only got 7 and 8. Go figures.
Usually Lte no problem but may not be able to get the 4g+ speed if they don't hv the band's supported in Singapore
It's not about LTE+ anymore for OP3, since it's lacking band 3, which is one of the regular LTE bands.
wildfaye29
Chat question rgd 4g/3g concurrently-
[–]kinghanson99OnePlus One, Nexus 6P, S7 Edge, OnePlus 2, Galaxy Note from Bin 3 points 7 hours ago
Is it true that the dual SIM cards can be used for 4G/3G simultaneously? Instead of one 4G/3G and one 2G?
Some countries are shutting down 2G services and we need dual SIM for both SIMs.
[–]aaron_oneplusOnePlus: Aaron, ROM team 3 points 7 hours ago
Data is only every active on one sim card at a time, so the network of the second card doesn't matter. If your second sim's carrier does not support 2g you will still be able to make calls and send text with the second sim while using data on the primary or whatever combination works for you.
[–]nlh7426SC8830 2 points 4 hours ago
Has any smartphone ever had that feature?
tclong
we don't ship to Singapore on oneplus.net, but we work with a local distributor. The OnePlus 3 will be available in Singapore soon! Stay tuned for news.
From OnePlus Singapore :)
Computeron
https://forums.oneplus.net/threads/rom-6-0-1-unofficial-cyanogenmod-13.450156/
CM out for op3
Sent from OnePlus A0001 using GAGT
Known issues:
Camera: HDR works, but you it closes after you took a picture.
F2FS: Not supported yet.
Battery life: Is not really as good as stock.
MSM8996: It‘s a new platform. Don‘t expect that CM 13 will run as good as stock
lalalalalala
Known issues:
Definately stock will be better at launch. But its good to see that cm already have a version in the works
lalalalalala
I used borderlinx cost calculator. Estimated shipping looks to be 77.29 SGD inclusive of $40 tax
If the citi promo deducts 25% off the total, shipping will be 58sgd add 5% rebate will be 55sgd
So total cost of phone will be 590sgd lowest.
garychengjw
