amazingone
- Jan 14, 2015
Yup, all local Oppo phones have Google Services preloaded.Does oppo r9 singtel sets have Google playstore installed?
Sent from my Rice phone using GAGT
the processor inside RMN3 is better than the one inside R9, but R9 has a better screen(at least for me) and 2 years warranty compared to 1 year for xiaomi Redmi Note 3. R9 also look nicer IMO.Thanks,I am considering between r9 and xiaomi note 3,dunno which one is better but I do know that xioami is much more cheaper and BTW does oppo have a service center in sg?
You have better get Redmi Note 3. It is an awesome phone with 4050mHA long lasting battery besides other Pros over Oppo R9!
Furthermore, Oppo R9 has 3000mHA only! Cannot last long one!![]()
R9 plus is 4120mah
then between r9 plus and redmi note 3, which one is better?Correct! Unless you get the R9 Plus... Else no point getting the R9 in comparison to Redmi Note 3.![]()
You either get the 6" R9 Plus or 5.5" Redmi Note 3 but not R9 at the moment.![]()
Does both the R9 and R9 Plus have the "NFC" features ?
R9 plus if you have the budget. R9 Plus is 2x the price of redmi note 3.then between r9 plus and redmi note 3, which one is better?
No NFC sadly.
MTK chips usually doesn't do well with GPS mapping, since its non-Helio series.the mediatek processor on r9 sucks... i use android auto and it has problems detecting my location. and gave me the wrong directions
It is worth while to spend more on r9 plus as it has a SD652 with 4gb RAM
YES R9 PLUS ROCKS
