Xiaomi Yi dashcam
nomoreliaola
questions: what seting u all use? i set to the highest one. u all leh?
also, the emergency recording is for what ah? do u set it then it will be enabled permanently ? cos got the progress bar
Maserati
For emergency recording, the video recording length is 20sec and it will be stored in another EMR folder. Normal recording are stored in movie folder which will be overwrite if storage capacity is full.
Anyone tried changing chinese filmware into english?
nomoreliaola
mines already in English.
So I guess no harm to let it set to enabled by default?
Sent from Samsung SM-N910G using GAGT
madcampus
Upz for this thread. Mods pls merge the newer thread.
$75 without warranty. $105 with warranty. Cheap and good. Easy to install yourself. Use wifi to download selected video via app, hence no need to take out microSD card.
IGfusion83
hi guys i just bought the xiaoyi dashcam and instal it on my windscreen.
2 qns to ask
which of the 3 video quality is advisable to set on?
Second question, which is also the most impt qns. How do i change the date and time on the cam?The default is 1/1/2015. And i dont see the option for date and time even though the manual say there should be one!
I downloaded the xiaoyi ap, it doesnt allow me to change date and time too.
Please advice guys. Thanks^^
slasml
i am using a 64gb card
max resolution
2a.
you download the app, hook it up to the cam via wifi
the time and date is auto-captured
2b.
update the firmware of the cam, which is done through the phone app. the latest firmware version the time/date setting
also
mine didnt come with 3m sticker, it has a proper suction mount
how much did you pay for yours??
i bought from qoo10 $80+ chinese version 6months local shop warranty
the app is in english and has full control over all settings of the cam. so regardless of the cam language, i am still using an english app:s13:
IGfusion83
i bought for 96 with the 16gb mem card.
Suction not holding well, so i pasted 2x 3m double sided tape, still holding on well.
thx for d info
madcampus
which seller selling the version with 3m tape instead of the suction cup?
Local dealer selling 3M stick type. Singapore weather not good for sunction type, it will not hold when the sun shines onto the windscreen.
madcampus
slasml
what's the purpose of emergency recording ah
iirc
3 level of sensitivity
upon impact, records "10sec before" to "10sec after" the impact
write protected file, stored in emergency folder
only downside, no motion sensor or parking mode
and i am using the suction mount, no problem.
clean the glass, wipe the suction mount
u can diy. its pretty simple. i did mine in 10mins
inside have instruction to teach u how.
true, its simple and fast
Hyori
any shop that help to install and manage the cable? too lazy to diy
madcampus
It's really very easy to hide the cable. As easy as tucking in your t-shirt. Just need a credit card or ez link card or petrol discount card, tuck the cable inside the rubber lining along the pillar. Go watch on YouTube. There's a link here somewhere in the thread.
