Xiaomi Mi Max
kelvinti
Sorry for my noob question here.
If bootloader is unlocked and use Fastboot via miflash, Data intact!
If bootloader is locked, enter EDL mode. Use Fastboot via miflash, data will be wiped out!
Is that correct?
algore
Anyone can recommend which shop in Sim Lim Square \ Bugis sells the Mi Max w/o modified ROM/ads ?
Thks!:)
anirudhks
Mine also stuck at 50%, consulted the forum, many likewise.with no reply. What now+
Sent from phone using GAGT
Can anyone advise how to check if the phone is already unlocked. I applied for the unlock code and gotten it. But when I want to unlock using the unlock tool. I alway stuck at 50%
for al those stuck at 50 % the correct way to do it is , make sure you login to the phone's Mi account with the mobile number you gave for unlock dont login with your email or username . Login with the same mobile number on the MI unlock tool as well. then run the unlock will work perfectly. unfortunatly no one on the MI forum posted this.
anirudhks
The OS part should remain the same except the boot and few other files , I will try to compile the MIUI* Global rom and the boot files from the china rom should be able to get us a global rom for the 64GB model .
Oinkize
Awaiting for you hardwork and good news...
touchme
thank you sir.
I tot that could be the case, cos I used another mobile#account to apply unlock permission for my own number, which I received otp and approval smses from. Guess what, after logining both, fastboot, stated my phone unlock not approved/eligible yet.
Btw, anyone can share the page to apply for unlock permissions again? Miui.com/unlock doesn't have the application link.
mac_oasis
thank you sir.
Are you talking about this?
http://en.miui.com/unlock/download_en.html
maxlovely
If you use chrome to visit the unlock page, you may not able to get to unlock page. Try to visit the miui forum or mi webpage and make sure you log off these webpage before you go to the unlock page again.
thank you sir.
