(BTO MAY 2016)
fxt0807
Not really, I have data on hand that shows drop out rates between 20% to 35%.
20% 177
35% 199
I am pretty sure you'll get to select.
Ah..i see thanks! Hopefully able to select.
If not need to ballot for Aug batch again :eek:
haihaiahjie
Got chance! But maybe not your most ideal unit?
Yah I also think you will get it. I think the 5 room q no includes 3Gen people too. Becos I remember someone mentioned her q no for AMK 3Gen was 17x/200. So I think the q no for 5rm n 3Gen are randomly mixed together. Any guru can confirm my belief?
My chances are slimmer than yours.
Charlene Zhang
Yeah the queue number is 5 room + 3GEN
3GEN supply is 52 while 5 room is 148.
Daisydreams
Hi, anyone can tell me the drop out rate for sembawang 2rm , i got 85X out of 610 , what are my chances like? 😣
ska13a
20% 177
35% 199
so base on those % u listed, just have to wait for them to call u if any? how would they communicate? am borderline so have to monitor the take up rate
windwaver
HDB will send invitation letter once they think you have a chance at selection.
ngcw81
first time apply, get q no 31x/247 at Bedok 4room... consider lucky or unlucky? any chances to get 4th floor above???
