Motherboard died?
spiky0180
My PC just died today. Last night I was using it and all worked fine.
This morning I turned on my pc, the fans spinned for less than 1 sec and then the power went off. This kept repeating until I turned off the switch on the PSU.
Eliminated PSU problem because I went to tech dynamic and tested the psu.
I returned home and tried to power on with motherboard + ram + cpu only and I can power it up once. After assembling everything, I cannot turn it on again. So I slowly eliminate the components one by one. Remove hdd, remove gpu, remove ssd, etc.
Now even with motherboard ram and cpu only I have the same problem. I tried power on without ram, tried changing ram slots to no avail. I also removed cmos battery but still cannot power up.
Most likely motherboard died?
jtjt00
If your Asrock mobo is under warranty, bring to Avertek at Kallang for RMA.
hlots123
cud be mb, but can u try cleaning the ram's golden contact region with a soft eraser juz to test test...
yusoffb01
u can always let them test motherboard + your ram see if can magically post there.
If can post then your room fengshui not good
spiky0180
Never mind. Think Monday I will bring the cpu ram and mobo to avertek. Gg
Damn unlucky. Now I on block leave from work. First day of leave computer die. Fml.
spiky0180
I realised my box states that warranty is covered by asview tech. I googled and asview and avertek has the same address. So I should assume that avertek and asview is the same thing right?
ZrE0_Cha0s
ya they are still the same company. but iirc now is avertek name. no more asview.
spiky0180
Tried cleaning the ram's golden contact and tried to reseat the ram in all 4 ram slots but to no avail.
spiky0180
Had the same problem as you some months back, it was mobo died. :(
You also using asrock motherboard? Looks like tomorrow suck thumb to to avertek in the morning. My worst nightmare is I go to avertek and the motherboard is working fine. Lol
jq75
Just make a trip there with ur cpu, ram and mb
Do u have another psu to test?
spiky0180
I already changed the psu. As in I went to tech dynamic. They tested my psu no problem. But just to be sure, they passed me another aurum s psu. The problem still persist, but I can eliminate the possibility of psu problem.
spiky0180
Managed to RMA my board. Avertek gave me a refurbished board I think, because the white parts on the board looked yellowish. So far my computer managed to boot up, with the occasional weird behaviour like restart computer and the monitor cannot detect hdmi input on both the video card and onboard memory. Will continue to monitor.
