Xiaomi Yi dashcam
cscs3
Local dealer selling 3M stick type. Singapore weather not good for sunction type, it will not hold when the sun shines onto the windscreen.
I use sunction type. Already few months. So far is good. The one provided is quite good quality.
IGfusion83
how much can your xiaoyi camera record before it overwrites?
For me i am using a 16gb sd card.
Within 24hrs, it overwrite already.Of course i am ubering 4-6 hours a day
is that normal?
my friend say by right should be 1wk?!
crumpler ish jin expensiv
is that normal?
Ideally you would want to keep the footage for as long as possible before it overwrites.. I download & archive my footage every day when I uber.
zenify.me
is that normal?
Play safe offload onto phone everyday?
ralliart_ray
Yah i use their ios editor to cut because yi duration is 3mins. U all boh see he beat the red arrows ah :(
Night video i go find
iduncheckmail
can someone share the link of the local seller selling the cam with 3M double sided tape ? thanks.
zenify.me
Easy to install?
straightforward for me since I didn't bother hiding the cable
mounted the camera behind rear mirror > connect cable to cam > cable loop 1 round around rear mirror > connect the other end to cigarette adapter > coil up excess cable
EJB
Not that hard to hide the cable.
Easy to install and use, easy to download the movie, edit and upload also.. hiak hiak hiak.
