graphics card failure?
StopJoking
was playing game halfway then comp hang. after manually rebooting then came to this screen with many horizontal lines.
anyone know whats the problem?
savoirex
Looks like graphics card problem. If it is a dedicated gpu, try reinstalling it?
StopJoking
im using gtx 680. have tried to take out and clean the gpu. still the same thing. my MB doesnt have on board graphics. so cant test further also
ZrE0_Cha0s
does your mobo have 2nd pci-e slots x8? if have u can test, else abit hard. not sure if x4 can work or not
StopJoking
just tried in the PCI-E x16 2.0 Slot(x4). i came back to the same page. and the horizontal lines still exist.:(:(
ZrE0_Cha0s
just tried. i came back to the same page. and the horizontal lines still exist.:(:(
den probably u gpu is gonna uplorry, else u can ask your friend to test and see. if really same issues, can start consider going for GTX 1070 :D
StopJoking
sian need to spend money again. haha. if get new gpu just slot in can already? or better to reset windows to remove all the programs
ZrE0_Cha0s
well u just need to remove the old driver using DDU for more safer way to sort of make sure it wont happen your new gpu.
next have u try using other cables for your display? like VGA, DVI, etc.
StopJoking
tested on a different monitor and still same thing with the lines
savoirex
How old is your graphics card? If it's out of warranty, last chance can try to 'bake' it in an oven. Must be conventional oven and not microwave. Supposedly the heated solder will flow over cracks and open circuits... :s22:
StopJoking
Out of warranty alrdy. 3yrs plus.
Only got those small oven use to toast bread. Won't release harmful substance? next time use oven for food how?
Phyber
I'm surprised no one suggest read the log.
Are u still able to access your com? Can post what is content of srttrail.txt?
Pls DUN bake it. This is a hardware not food. Dun contaminate the microwave. PLS no no no.
OKorNOT
Diy pc?
Get a branded 1...
diy pc alway problem...
U can last 3 yrs not bad alrdy, mine 2 yr breakdown alrdy
Phyber
Diy pc?
Get a branded 1...
Comparing apples and oranges m8.
What you see as a "breakdown", someone else sees it as a "learning experience".
2 different people buy car. Some just drive for work, some like to zhng. Both are not wrong.
StopJoking
yea man! diy is the way to go. at least u know what parts you have inside. any problem can consults the experts here also
Diy pc?
Get a branded 1...
my gpu always breakdown few months after warranty....
cant boot into windows anymore already. i tried to reset windows using the troubleshooting. but the lines still exist. hahaha
ZrE0_Cha0s
if not u can try to access to safe mode,
not sure if this steps still works or not :
1) reboot ur pc
2) press 'F8' multiple time or after bios screen press and hold
3) select "safe mode"
if u still cant work need to search for how to go to safe boot in windows 8/8.1/10
jas1701
That txt file might give you some clues of what happen. 1 thing notice how come your windows is in drive D. In order to see the txt file, need utility like paragon recovery, is free download and able to bootup to see your drive data.
https://www.paragon-software.com/home/br-free/
Not sure if this is the link above.
Last time my laptop HD problem cant bootup, i use this to bootup and copy all the data into an ext HD and get a new HD.
StopJoking
i could still boot up yest. tried again today but after the loading windws logo the screen just go black
Phyber
OK good at least u can see windows logo.
Try boot into safe mode see how.
Where possible extract the log and see what it says.
