u need to unlock bootloader first
is it hard to flash to global rom?
Any shops selling with global rom?
Wah lau, that is super xiong project leh.
Just download and install this :
http://download.cnet.com/EaseUS-Partition-Master-Free-Edition/3000-2248_4-10863346.html
Then you can format the 64GB microSD card to FAT32 liao.
I am using 128GB with FAT32.. no issues except the fact that you can't save files which are larger than 4GB.
I've also modified my nano SIM, and stuck it on my microSD, so now I have 2 sims and one SD Card..
I was doing this yesterday also.. I took the chip out easily but I can't slot the SD and Sim after sticking then together man.. I sand the Sim and SD card also cannot.. Any advice? ��
Did you pull out the entire metal piece from the SIM?
If yes, after removing, you'll still need to heat it up to remove as much glue as possible from the back of the metal portion. I put the SIM on a spoon and used a lighter. You could do a more controlled job, by using a heat gun.
Next, take a razor/pen-knife, put it at an incline, and start scraping off the glue. Takes a good 10-15 minutes, to carefully do so. The end result will be a wafer thin SIM, with a small protrusion at the centre of it.
Next, use a very thin double side tape and align it on the MicroSD (i didn't need to sand my MicroSD card) then put a small drop of superglue and spread it out like kaya on bread, after which, align your SIM onto the SD card.
Do note that there is increased resistance when slotting the SIM tray back for the first time. You'll need to do it slowly and gradually, lest you damage your SIM pins inside the phone.
After a while, I can however still take out the SIM tray with no issue, only slightly more resistance, but it is otherwise smooth (not like it's puling against the SIM pins)
I used double sided tape only and the Sim chip moves as I slot it in.. But I have another problem of the SD card not detected.. I think I better solve this before I use super glue to stick the micro SD and Sim.. BTW, where u got your phone from? Simder or Newstar?
You are good, man!
No everyone can do that!
One really needs a steady mind and steady hands and legs!![]()
Naise.....,
Wow!!!
Impressive!!!
Get the 64GB!Anyway, sold off my spare phone already.... Just need to folk out $80 to grab the Mi Max 3/32 or $150 for the 3/64 if I want.... Kekeke.
