PanGu iOS 9.2 - 9.3.3 Jailbreak [English Version Released]
i.Singaporean
They say it is semi-tethered, isnt it?
Yep
This is not an un-tethered jailbreak, they're saying its tethered but for some reason it does not require a PC to boot each time. A reboot will remove the jailbreak state, then you run an app on your phone to re-enter the jailbreak state. It's only tethered in the sense you lose JB on reboot but don't need a PC to re-jailbreak
Twilight
Trying to get it jailbreak..
It shows a chinese version of ifunbox..
No green button to click to jailbreak
Unable to jailbreak..
Anyone managed to jailbreak?
eyz
finally, been waiting for this for almost 8 mths.
luckily the semi tethered doesn't require a PC to boot up.
rebooting the phone will render the jailbreak lost, and all one need to do is to go back to the website and jb again.
RadEoNic
But if you restart then everything will be gone?
Then got to install everything after jailbreaking again?
crunsik
only a matter of time before the untethered version is out
Pangu iOS 9.3.3 Cydia
As mentioned earlier, this is a semi-untethered/tethered jailbreak which means every time the device reboots, you will have to re-jailbreak of sorts to get the device back into jailbroken state. Fortunately, this doesn’t mean you need to go through the whole process through your computer again. You don’t have to reinstall the jailbreak tweaks, settings or Cydia either. All you need to do after every reboot is to run the PP app from the home screen on your device and tap that large circle button to get back into jailbroken state again within no time.
collin86
I jailbroken 9.3.3 successfully, but faced an issue on both iP5s & iP6s-Plus
some of my 3rd party apps open and close(failed to launch), deleting and reinstalling does not work
the apps are:
FB messenger
RadioTunes
SG Radio
Shazam
Gmail
haven't got time to try all, but anyone has any solutions?
dawntime
This JB needs to pay? I'm stuck at that app page where it tells me to donate $$$$
