the ONEPLUS 3
8-lane
Yay! Dhl delivering tmr. That's 3 days from order on Sunday evening to deliver from HK by wed, FAST! But i had to delay it to Thursday though, in order to pick a better timing :(
Congrats.. !
looper1994
Already mentioned, OnePlus has a "service" centre, but does not do servicing. They simply do one-to-one exchange once you have got RMA. And no, Lazada does not care about defective items, only refund in 7 days.
OnePlus is not for you if you concern about warranty. Just take it as non-existent warranty, or try your luck.
Quoting this again:
I see. I guess one to one is better than nothing. Thanks for the advice.
vickyboi
Still looking a good / suitable tempered glass protector.
Am using a black spigen casing I got from Mobile Hardware at bencoolen and its pretty sweet.
Open to any suggestions on screen protectors. I know tempered glass ones for this phone haven't had many good reviews.
Sent from OnePlus ONEPLUS A3000 using GAGT
adan197
Replacement SIM tray
Hi,
I've made the mistake of misplacing the SIM card tray..
Does anyone know if there is an outlet that sells the replacement?
Would OnePlus be able to help?
Really hoping for a miracle here...
Many thanks in advance.
crandfs
Bwahahaha!!!!! I have it!! My precious!!!!
* Although now I'm regretting a bit for not spending $18 extra to get the gold, because I prefer a white front, but hopefully the full faced tempered glass I taobaoed will be able to give that effect...
Got it for $590 from Geeks at qoo10, HK to SG in just 3 days. No need pay GST :D
Freebies
  1. A very nice clear soft case that protects all round the sides. This case also has a slight raised edge around the protruding camera and all around the screen. This protects both glass surfaces when putting it back down on flat surfaces, but still need to be careful not to put on rough surfaces because it will still get scratched, especially the raised edge around the screen is a bit wobbly, so dun expect it to stop the screen from hitting the floor if it does manage to fall flat on its face .
  2. Plastic screen protector. And it comes already perfectly applied!
  3. Tempered glass SP!
  4. USB lamp, 3pin adaptor
However, both SPs are flat so they do not go all the way to the screen edge which is curved :(
Haven't turned on yet, cos I want to charge it fully first, then experience it sekali later find it it's spoilt cannot run, then you'll start seeing me post lots of shitty comments about the phone and seller liao.... :s22: It charged from 51% to 88% while I was uploading its pics to facebook and typing this post... :s12:
crandfs
Hi,
Even taobao dun have for now. I looked on taobao, alibabaexpress and ebay. Think you better contact their distributor here directly
fowler985
Today my one plus 3 suddenly could not hear e ringtone sound when someone call me. I have adjusted to e highest volume, restarted my phone a few times and even change ringtone. System update is latest oxygen 3.2.2. Anyone face this issue?
asia65
Hi, did you check your "Alert Slider" switch? It is at your phone left top side, is like Iphone sound on/off switch.
D24ox87
anyone can help on oneplus 3 local set data cant connect i try apn setting all correct i can receive call and sms. just i cant connect to data there's a ! at the network sign?
hellhole
anyone added tempered glass on their one plus3 ? i was told in a shop at sls that the front screen is curved and that when u put the glass on.. it will create bubbles... anyone has an example?
hellhole
go to setting>cellular network>access point names... choose another one... and see if it works... for M1 it is sunsurf
3ddicted
Anyone bought from Oneplus HK before national day? I managed to get it, heng still have cos now they also OOS till Sep 12.
But they take very long to ship, 19 Aug den out, den will reach my borderlinx HK addr on 22 Aug.
Btw i use the borderlinx calculator I have to pay ard $90+ just to ship back SG.
End up total amount close to $700, same as $699 local set.
Hopefully its worth it!
crandfs
AIyah, get from Geeks at qoo10 loh, ~$600, also shipped from HK but reach in 3 days, plus they will flash the ROM to Oxygen for you, apply SP, and include a nice clear soft case. No GST, shipping fees also included in the ~$600 price
