kelvinti
- Jan 5, 2009
Is redmi 3 different from redmi note 3?
Different model.
Quite different.
The Redmi Note 3 can be thought of as an upgraded Redmi 3 in every regard,
from a much higher performing modern SOC (the Snapdragon 650) as opposed to the Snapdragon 616 (iirc) which is a few years back.
There's a larger screen and a finger print sensor found on the Note 3 as well - making it comparable to flagships of 2015 / 2016.
Cool.........Beta 2 of cm 13.0 rom out in the wild:
http://forum.xda-developers.com/redmi-3/development/rom-cyanogenmod-13-0-ido-beta-1-t3430791
For 3S only, flashing it to 3 may brick it.anyone apply the global room on the china version ?
Redmi 3 and Redmi 3 Pro are basically the same phone, just that 3 is a 2GB/16GB model while the 3 Pro is a 3GB/32GB model, and comes with fingerprint sensor too.There's a qoo10 seller selling Redmi 3, Redmi 3S, Redmi 3S Pro, Redmi 3 Pro. Can anyone care to tell the differences between them? Gsmarena doesn't really tell me much (or maybe I didn't read carefully...)
Also, how is the fingerprint sensor on the Redmi 3/Xiaomi phones compared to other brands/higher end Xiaomi eg Mi5?
I read the previous posts and found out that there are beta CM13 roms for the Redmi 3, has anyone flashed the rom? Are most of the features working with every update?
Thanks
Redmi 3S and Redmi 3S Pro are also basically the same model too. 3S is a 2GB/16GB while 3S Pro is a 3GB/32GB, both comes with fingerprint sensor.
Redmi 3 features a SD616, while Redmi 3S features a SD430.
Sent from Sumire using GAGT
Hmm speaking on this, it's quite fun haha~which SD is better??
SD616 raw performance will be better than the SD430, but the SD430 has a better GPU and better efficiency level, which will mean it will have a slightly better battery life too.
SD430 also feature an improved image sensor processor too and supports X6 LTE.
The upcoming Redmi 4 will be featuring the SD625, so if you can wait then see if you prefer the 4 or 3S or 3.
Upgraded to the global developer rom on MUI 8. Seems a better, without the issues of hanging/out of memory. But still Lollipop. GPS had some issue as I flash it with the data intact (had to clear the GPS data separately)
