The Watch Thread - Part 10
indigo22
i am thinking of getting the watch case you got too sia.. so tempting :s13:
cheap cheap just hoot..i like cause the top is cushion, so even if ur watches too high, it (the watch face) is still well protected and cushioned..
its also cushion that ur watch wraps around..so its not bad..can keep up to 4 watch straps on the cover of the box :o
Turbo-lised
but the shipping close to 5 dollars sia :s13:
still considering .. but its so nice
m0lecule
Sinn is well known for their tool watches. Very solid and substantial when worn on the wrist. On the other hand, Junghans watches are dressier. The overall design is classier and more refined. Tough to compare the two brands. Buy the watch that calls out to you more. Or buy both :s13:
going Germany soon, pondering to buy either junghans or sinn, budget 2 to 4k.
which one is a better brand or got other brand within my budget?
m0lecule
Back to the sub
gaoxing84
Hahaha yeah, I think can test and try not to over-wind.
I think some of the higher end watches like Omega also provide recommendations for watch winder use, seen manual before.
It's a bit of a conundrum - even if you don't put on winder, there's going to be some wear and tear if you keep setting the time, especially for screw down crown. Putting on winder arguably can also work the watch unnecessarily.
I remember GX said that winder is probably 100% necessary for watches with no quick set date.. Can imagine man.. Quick set is still ok, you can usually set in less than a minute. If you have to advance the hours just to move the date.. :s13::s13:
Winders aside, I keep thinking about the Wolf watch box someone posted recently, jin swee sia. And the spacing is quite good. My cheapo Qoo10 one like not so good for larger watches. :s11:
YES, you need a winder for non quickset date watches, will die. lol tried once and i buy winder liao. buay tahan
no choice for vintage watches
cyrenic
But some vintage watches don't have anti-overwind protection right? Then that one really need to be careful hahaha.
m0lecule
IIRC, automatic watches cannot be over wound, i.e. the mainspring cannot be damaged by excessive winding because of the clutch mechanism. I believe this applies to all automatic watches including vintage ones.
Manual winding watches on the other hand, can be damaged through overwinding because they generally do not have a clutch mechanism. But in the context of watch winders, it is a moot point since u can only wind it manually through the crown.
gaoxing84
haha my rolex have the mechanism to prevent overwind.
but its ok la, 650 tpd is not alot actually.
pwillie
I bought from clemiko and K&L before. K&L is a one-man operation. Boss is v friendly regardless whether you speak Cantonese. Clemiko peeps abit more serious. Not too sure about watchoutz though.
Sent from Samsung SM-G935F using GAGT
Watchoutz range is good, however not much of bargaining though, they have friendly English speaking sales assistants.
My Padi preordered from there.
m0lecule
Ahh.. I did not check them out during my last trip to HK because K&L was the only one that has stock of the SBDB009 then. Shall drop by during my next trip there :)
shorty07
I think it's on the higher end leh.
Usually this price range is diver watch, arguably the case and sealing should cost more I think..
For semi-casual/dress watch with Miyota, usually around 200-300 USD thereabouts.
For example, Belos: https://www.kickstarter.com/project...ovement-in-the-stockholm-archipel/description
Travisleon: http://travisleon.com/
But this watch ed yeo posted, got diver also. Hv u seen the website? U can choose the kind of case u want. So thats y i say not a bad price. Ive seen other microbrands with similar pricing for diver watch.
gaoxing84
those want a good single motor boxy winder can try tresor winder.
70++ only.
solid man, my rolex sub is in it permanently. haha
http://itresor.com/
cyrenic
The 400+ EUR Miyota price is done with normal case. :(
41mm round steel case
Fixed bezel polished
Miyota movement
Numbers dial
Leaf style hands silver
Red seconds hand
Big straight steel crown
Dark brown natural leather strap
Classic pinbuckle
Backside mineral glass
395 Euros... That's pricey sia. Ok but diver case still same price. :D
You're probably paying a premium cos of the lack of mass production I guess?
Ed.YEO
Miyota movement
Numbers dial
Red seconds hand
Classic pinbuckle
相比之下,其他採用Miyota9015機芯的錶款在價格上的的確確佔較高的優勢。但是Revolo的賣點是個人,個性化生產。
個性化生產的錶,優缺點都有。
最大的缺點就落在價格方面。。。
優點咧?
一,不會撞錶。
二,就算撞錶了,帶來的不是“一樣的那麼~~~:vijayadmin:普通:vijayadmin:”的負面感覺,
而是“咦~~~我們的品味一樣的?!!”:s8:
pwillie
Bro u are right won't cause problem to the watch in general but the clutch slip mechanism which help to tank the over wind may wear out faster than normal.
So short term should be ok. But 2 years on winder dunno have how many factor of wear and tear compare to normal use .
Anyway since I bought I will use but maybe with some safeguard haha
Not for the modern automatic watches
the slipping clutch was designed before 1900 iirc, unless your vintage is over 100 yrs, it is in place.
but that said, some say that older vintage watches have mainsprings made of alloys with lousier elasticity, and that can mean the locking mechanisms get worn off by the "hardened" mainspring due to constant winding.
gaoxing84
the slipping clutch design was in place before 1900 iirc, unless your vintage is over 100 yrs, it is in place.
ai seh willie! chio and smart! where to find.
cyrenic
I see, not much experience with vintage. :D
