johnsonheng
- Aug 1, 2002
You saying there on international rom for 128 GB
Both lines support 4g. But when 1 set set to data, the other sim will be 3g/2g...
ermm u mean if i set default for the internet then it will be 4g n 3g?
how to know whichis 4g or 3g?
if i do not set then how will it ultilise the data usage?
sorry for so many qn as i just tried..
If you dun set which sim for data, you will have no data.
That sim set as data can go up to 4g whereas the other sim can go up to 3g only.
You can see the network when you pull down the notification bar...
oic..i do not see the network when i pull down.
it just show singtel 3g and singtel 4g at the top bar
the updown arrw left of 4g means it is using 4g?
No eap-sim?? Cannot connect wireless sg?
What the difference between China rom and global rom. Beside the playstore
One is meant for china market, one is meant for international market?
There is EAP to connect to wireless@sgx in mi max. Click the arrow on the right hand side of wireless@sgx and choose sim and click ok on the top of the page. I'm using it now.Eap sim for wireless@sgx only...
Those on miui 7, u all received the update to miui 8. I still din receive it
I know, what I means is the performance
