OnePlus 2 - NEVER SETTLE
batboyz
Anyone has the phone's fingerprint sensor function missing? Mine went missing for couple of weeks. Research on web and did a reset. Also no use.
Yup, same, actually went missing/undetected for few months, but mysteriously came back last week, and still working well till today. Also did factory reset, wiped, etc, even flashed CM13 nightly from oxygen OS, etc, also no love.
imreallyugly
Guys try this, i worked twice for me.
I read on xda to drain the phone till 0%, when the phone shut down, keep turning the phone on, till it can no on at all.
plug in and charge till 100%, without unplugging the charger then power on.
disable the hardware keys, it should be working then.
Hope this helps.
batboyz
Hope this helps.
Already tried, did not work for me. Hardware keys have been disabled for a while on my OP2, since the home button did not work (home button stopped working before FP).
aLeX84
Does anyone know where to get a replacement screen locally for OP2? The Corning Gorilla glass on mine is really badly damaged from a few falls, cracks running from top to bottom but surprisingly the digitizer is still working and there are no black patches on the LED display below though I suspect it won't hold up to another drop :(
Any help here much appreciated :o
summersky1986
wtf i just joined the ranks of those with home button dead... now using onboard... damn annoying..
gonna do the batt drain method now
batboyz
After 2 months, the first fingerprint sensor still not working. Crap, not going to buy another OnePlus phones ever.
Good thing my wife's OP2 FP is still working well, even though it was dead for few months before.
sleepyjoy
OxygenOS 3.5.6
Has anyone installed the new 3.5.6 OS OTA? Any issues? :)
Or has everyone changed phones? :s13:
seowbin
I have this 1m or 1.5m usb C cable spoil for like 6 mths liao. Ignore my email. Really weak. Not going to buy anymore of their product liao. Fu*k up
Think by now warranty over
weikang2753
anyone faced issue that not able to get signal for SIM 2? as SG shutted down 2G network.. :(
no matter on OxygenOS or LineageOS..
ancellim22
For those still using this phone, is your battery life worse than before? My set loses ~4-5% after booting up each day. Been using since Sep 2015
