Google Chrome Crash Randomly
*adiBOY
My Chrome has been crashing randomly after a couple of minutes for no reason at all. It can happened at any page. I tried googling for the issue and have tried all the recommended methods like uninstalling and installing, reset user profile and checking for malware (got none) but the crash still persists.
Anyone had the same experience before who managed to solve it? :(
*adiBOY
Thank you for the replies.
disable hardware acceleration...
I will try it later tonight when I got home. The weird thing is, the random crash only start to appear last night when I tried to do iBanking transaction.
Disable extensions and plugins..
Already delete and reinstall chrome, no more extension but the problem still persist.
ZrE0_Cha0s
try using private browsing? and have u try to access facebook and hwz? do they crash as well?
moodless
Deleting and reinstalling does not remove extensions and plugins cause your settings are saved in cloud and will be loaded back automatically when you sign in
yusoffb01
in my experience when chrome cause the whole computer to hang, culprit was graphics card
*adiBOY
I haven't tried incognito mode though. But every website I go, it will just crash randomly after a while.
My com didn't hang though. The chrome just crashed but was working fine before.
See what can you do with chrome://flags
I didn't want to go into that at the moment.
I don't know if it's a problem with windows update. I was using normally until i was prompted to restart my com for updates. But I think the last windows update is for office only. Anyone can verify?
*adiBOY
I reinstalled but did not sign in and there was no extensions.
