Xiaomi Mi Max
ipaq4444
As someone mentioned earlier, even external USB via OTG adapter needs to be in FAT32 format. This is one thing I disliked about Xiaomi devices. Last time used the Redmi 1 already had this issue. All my previous Androids (Samsung, Asus, Sony) have no issue read/write onto exFAT microSD cards or USB storage.
Does that means if want to store those more then 4g per file movie then must get the 128g version mimax
i1magic
The case I am using is this one with the i-Ring.
With this way, I can reach further and yet the phone will not slip out of my hand.
KalTorak
Yupz, no way around it. Just get the bigger 64G/128G Mi Max if you need to store large sized media files (>4GB) on the phone. Xiaomi is really behind in supporting exFAT. FAT32 is damn ancient file system. I think they just not willing to pay the $$$ for it.
Shadow79
Actually you can use the app Nexus Media Importer to read exFat/NTFS formatted OTG USB drives.
i1magic
Can get the case from here.
Do take note that this case will have cover for the 3.5 mm audio jack and the micro USB port also. If you don't want them, just cut them off.
NOTE : At the espense of better protection, this case makes the phone feels thicker.
Item : Xiaomi Mi 5 / Mi Max Hybrid hard shockproof matt back cover
Price : About SGD$3.70 (Mi Max)
Source :
http://www.ebay.com.sg/itm/182211484774
As for the i-Ring behind.
Item : 360' Hook metal ring stand holder mount finger grip
Price : About SGD$1.40
Source :
http://www.ebay.com.sg/itm/360-Hook...hash=item3d1e8100f9:m:mnOR-Zs64VsqIJLV-v6bT8A
