Xiaomi Mi Max
kandinsky
Whr to buy? Wat brand
This kinda thing no brand one. Can buy from aliexpress? Case US$2.63 + Ring US$0.94, roughly S$5 total.
http://www.aliexpress.com/item/For-...Phone-Cases-For-Xiaomi-Mi-MAX/32702343821.htm
http://www.aliexpress.com/item/Free...ile-Phone-Holder-Grip-mobile/32630635359.html
SPEED
anyone here using the global beta rom?
the stable rom like many bugs
philips110104
Collecting my phone tonight :D, can SIC the safe way to unlock, root, install TWRP Recovery, install global ROM? Want to do these before i start using the phone. TIA.
kelvinti
I'm using it and that global beta rom is much better and speedier and smoother than global stable.
In fact, quite a lot of us here are sticking to Global beta rom. :)
You should flash to global beta 6.9.8 asap. :)
SPEED
ok man
shall do it soon!
Thanks!
You flash using fastboot option?
hachi
Got my mi max and played with it for 15 mins. Concluded is a good buy, best buy and must buy phone. Buy it as spare or watch YouTube. At this price you have nothing to loss. In fact I thinking of changing my wife phone to mi max as well.
Oinkize
Did you buy it from hachi.tech?
Almost read it as change wife to mi max...
Hahaha...
kelvinti
Ya. That's what I use my Mi Max for as a secondary phone, be it at home or on the go and that helps to minimize my battery usage on my Note 5 as a primary phone.
Go get your wife this Maximizer asap. :)
At $300 price range, no need to think twice. :)
