[Software Update] iOS 10.0.1 Discussions
ukyo100
After update to my iPhone 6s Plus.. so far no issue at the moment (touch wood)... quite enjoy it...
PongRareRare
So far I liked it as well, but there's 3 bugs? that I noticed
-keyboard
After ... there's no caps like last time.
After going to the numbers and symbols window, previous version will change back to alphabet after space but after update, it remains in that number and symbol window.
-launch app from notification
After received whatsapp message, I can only 3D Touch the notification to quick reply window den tap to launch app but if I receive more den 1 notifications, I'm able to tap and launch the app through the 2nd message.
-App Store
At the updates window, I cannot leave reviews.
eurofunk
Think it's part of the "plan" to make previous Gen phones slow down with each major software update otherwise how will a brand continue to sell their newer phones if the previous Gen phones are always speedy and good with each update
jq75
Seems many functions go well with 3D Touch.
My torch can either on or off only
charleslin
My iPhone 6 non S no diff in speed, no slow down.
tansux
ios 10 is configure to be like android home screen. HAIZzzz...HATE THE LOCK SCREEN HOME BUTTON .. now have to keep pressing the button
mikeeeey
Go to settings. Accessibility. Home button. Can go back to just rest without pressing. This was shared by a bro here
tansux
After Accessibility, which option should we select ?
click speed or rest finger to open:s11:
szeli
apple shud have kept slide to unlock for non raise to wake/touch ID folks. quite annoying to be honest :s22:
tansux
being force to click and reduce the life cycle of the button really sux.
now need to think of a way to downgrade it
szeli
but u got touch ID right? since u say u can see "rest finger to open"...
