Xiaomi Mi Max
i1magic
Thanks for the reply. I tried but the MiFlash tool couldn't detect my phone at all.
There are some important steps that you need to do.
I followed this :
http://en.miui.com/thread-235865-1-1.html
But you must take note of 2 things :
1. Install MiFlash using the Default folder which they specified
2. All the folder's name CANNOT have space
This are the 2 things which I corrected and managed to complete the flash.
i1magic
Can we use any brand of Microsd card for mi max?
Or do I have to buy a specific brand that can only be formatted to Fat32? Sorry that I'm asking stupid questions. Really have no clue.
Any microSD card should work fine. Yes, must be FAT32. If you want to format any microSD card that is 64GB or bigger, you'll need 3rd party program.
touchme
Har? What happened? Got picture?
Fine line, 1 cm away from right edge.
Swam in water, and dropped few times before. (initially without case/tgp).
Small issue.
Sent from phone using GAGT
este87
Morning to all. May I know if your Mi Max still freezes after the new Pokemon Go update? Thanks in adv :)
hachi
No, played very well. Anyone have any issues on the security of the fingerprint unlocking.
Yesterday I wanna impress my wife on this new feature which I find it useful. She can also unlock using her index fingers despite I recreate my fingerprints profile.
sumkong
Dropped my phone at the car park this morning. The phone had a transparent plastic case but still caused a hairline crack at the lower left corner. Lucky was not those flowering crack. Best part is I didn't feel too much pain, lol. If this is an iPhone with only one month old, heart will be damn pain.
laironpark
Qn abt unlocking bootloader - if I have already unlocked the bootloader, do i have to wait for another 30 days before I can re-flash the same rom?
Nakedtoes
Tpu case or hard plastic case? This gorilla glass is worse then China glass of note 3
hokeylim
Those on 32GB Global rom, do you get very low volumes on your call ringtones and teleconversation ?
I read on the MIU forum that many complain about low volume. I'm still deciding whether to get mi max because of this point.
Nakedtoes
No problem so far... Nv miss a call.
kelvinti
Ahh! New Mi Max folks,
Don't forget that one can Double Tap to wake screen in MIUI8 just likes those LG phones. :s22:
There is an option to enable it in Settings. By default, it is turned off.:)
Nakedtoes
Somehow it is too sensitive.. I put inside pocket the screen always on.. So I off the feature
