Xiaomi Redmi 3
foxbat
Step 1: Apply for MIUI unlock permissions. http://en.miui.com/unlock/
You will receive a SMS in about 1 or 2 days
Step 2: Download and run MIUI unlock software
http://en.miui.com/unlock/download_en.html
If you have more than 1 Xiaomi phone tied to your MIUI account, it might give an error, so delete other profiles.
The bootloader will then be unlocked
Thanks
I've already unlocked boot loader.
Which link for global dev rom install :)
Saw a few but wondering which is more accurate. Quite different some steps!
mokseng
There's a qoo10 seller selling Redmi 3, Redmi 3S, Redmi 3S Pro, Redmi 3 Pro. Can anyone care to tell the differences between them? Gsmarena doesn't really tell me much (or maybe I didn't read carefully...)
Also, how is the fingerprint sensor on the Redmi 3/Xiaomi phones compared to other brands/higher end Xiaomi eg Mi5?
I read the previous posts and found out that there are beta CM13 roms for the Redmi 3, has anyone flashed the rom? Are most of the features working with every update?
Thanks
Just get the cheapest one.
8-lane
Thanks
Redmi 3 does not have fingerprint sensor
SPEED
Just ordered a Redmi3 16GB Gold from Lazada for $137
Going to flash the Global rom on it.
Just to check when buying from lazada is the set sealed or has been opened?
should be opened, they open to install playstore inside
SPEED
Anyone can help me flash the phone to latest global stable ROM?
It comes with this tampered rom ver 7.1.1.0.0
accucore12
Can recommend which lazada merchant u all buy i redmi 3 or redmi 3s from. I intend to get either but dunno which lazada merchant is reliable
knightcover
Anyone bought their RMN3 pro from lazada smartcell? Wanna hoot from them but unsure if it comes with global rom. Understand from the helpful guys over at the mimax thread that the mimaxes came with global rom though. Not sure if it is the same for RMN3 pro? :s22:
kelvinti
If this is the one you are referring to:
Xiaomi Redmi Note 3 Pro 32GB (Gold) SGD 218.00
The Pro version that SMARTCELL has is the Indian set which comes with Global ROM! :s22:
No worry! Can click to buy now! :s22:
