Xiaomi Mi Max
sellun
GF dropped her phone from around 1.2m height straight onto the hard floor... Screen Protector cracked, casing have scratches. But nothing happened to the phone! Lucky lucky!!
But now need to wait 2weeks for new screen protector...
Sent from MiMax using GAGT
kelvinti
Funny thing is that there is only Gold or White or black plate.
There isn't any Silver plate for matching a silver Mi Max.
At least, I couldn't find it so far.
Plastick
Do let us know if it's China Set/India Set; Global or China software rom....
Thanks in advance.. =)
on the same day, i phoned smartcell, was told this is india set. hence it is already pre-loaded with global rom already.
i1magic
Wah ... from 1.2m is quite high. Which casing is the Mi Max on? As for the screen protector, it is so cheap that just buy one for standby.
Now I am thinking whether should I buy gold one or black. Black colour will make the whole front part looks like screen, which will appear huge!
i1magic
Btw.. mind to ask.... is the tempered glass screen protector and the casing with finger ring attached... available locally?
You can try Carousell or Qoo10. If they don't have, chances of shops having them will be remote.
kelvinti
But hor... The black one doesn't match well or blend in well with the side silver or golden bezel as there is still tiny gap. Kekeke.
Go for the gold lah. Kekeke.
hellojeffo
Guys be careful with your volume rockers. They are very soft.. I left a pen together with my mi max in my pocket today, somehow the pen pressed onto the volume rockers and bent it inwards.
The rocker got stuck and I couldn't press volume up or down. I had to tear apart the backing to bend the rockers back to shape.
It's working fine now. Good that the back is pretty easy to rip out..
kandinsky
Why did you opted for the white one? I mean the black one at least still make sense.
Cos from the pics I saw of this protector, around the screen, there's still a tiny border of the original bezel that is visible, so white still looks the most seamless against the original white.
xMExHKSx
Hi,
Anyone have problem with calls? The volume is always high, and cant be controlled using the volume rockers. When controlled in the settings the media volume, it will be re-adjusted back to the original loud volume, without changing the slider, seemingly like a auto-volume or something like that.
i1magic
Did you use a case for the Mi Max?
i1magic
Hi,
Could be the volume button jammed.
icefox2004
While waiting for the screen protector to arrive...u better get a cheap screen protector locally before she drop again. Lol
