hellojeffo
- May 10, 2007
Did you use a case for the Mi Max?
Yes I used a case.. but it's a flip cover and doesn't protect the right side.Could be the volume button jammed.
It's stuck because the volume button got bent.. I had to rip the backing off to unbend it.
Check out Mi Forums.. there are a few similar cases
