Xiaomi Mi Max
virtualape
Or buy 2 sets with local warranty and spend less than 300 for each ;)
thats a good deal.
Good for those who want to share the savings. 2 pieces seems to be the best deal.
touchme
Sianz, received 2nd set from smartcell, but sealed and Chinese box, means China Rom inside?
SPEED
no issues with that
You can just flash it to global stable or global beta ROM easily
most important is getting the cheapest deal you can find.
china set or india set all is made in china
No difference
just box design, the ROM and the charger is diff
kelvinti
Not necessary! :s22:
Smartcell might had opened it, helped you to pre-loaded the Global rom for your set, then sealed back again and then Ninja to you! :)
Great service! No harm done! :) Report back please..........:s8:
kandinsky
Don't worry, most likely they flashed for you liao then seal it. Mine was CN set, arrived sealed and flashed to global. The standard sealing anyone can do one.
Veloso
When did you place order?
Anyway, was browsing tb for tempered glass, they got two different types, 丝印 and 碳纤维. Which one is better?
touchme
@kadinsky and kevin, the miMax dominants here, thks. Then can flip sealed to the naive..lol
kelvinti
Smartcell does it with good intention. That counts. :)
It actually helps a lot of users who are not too sure about how to flash to Global rom. :)
It benefits both parties. :)
Excellent services, I would say. :)
Rather then other sellers who just sent you a China rom set and ask you to fak yourself...Opps! I mean flash it yourself...
bockers
The actual Indian version is made in India. It says so on the back of the box. Made in India.
no issues with that
No difference
