Xiaomi Mi Max
Just Me
ok thank. let me go and read about the diff of 32gb and 64gb export set. Why there are still people buying 64gb since cannot flash to global yet?
More capacity? But ram and processor still same as the 32gb model unless you buy the 128gb one
roidred
I didn't try it but there ROMS to flash from xda or we can install Google play apk to get play store. I am still going for snapdragon 652 and 64gb. I am still interested. Please let me know your research outcome.
ChrisTang
If i buy 32gb, cannot reach $600.
SPEED
Now ninja van offer you a choice to self collect at various collection points?
roidred
32 GB has snapdragon 650 and 64gb one got snapdragon 652. RAM is 3GB for both model. For heavy users 652 makes sense. For normal users Snapdragon 650 is more than enough.
heng_ah
Wah so fast this week gotten the OTA update for 6.9.22, attached the changed logs, haven't update yet as always dl the package and go through twrp.
Any bro has updated with latest latest beta can confirm if this release has solved the sound problem with soft ringtone?
I rooted mine, every time updated, it reverted back to unroot rom and I have redo root proces. Very sianz... If not critical, I rather not update.
ChrisTang
Do you mind to whatsapp me at 9898-9996 Serene. Thank you.
ChrisTang
Can i check with those using 64gb, is the google map as accurate as local set? Is it as stable as local set as well? This is very important to me because I travel around quite alot everyday. Thank you.
Oinkize
No issues for me, Serene...
Nakedtoes
Thinking of getting 1 more mi max for mine right pocket... Left 1 right 1...shiok
