I use local backup in settings, wonder if it's full restore after Rom change? (Not tried restore yet)
Open the folder, tap on the folder name and disable 'Promoted apps'.
Anyone knows how to get rid or disable Promoted apps?
Where is this promoted apps found?
Hurrysep30 is only applicable for payment via hellopay. Under hellopay there r 2 payment option, installment or one-time full payment.
(on local backup).Yes, application only.
Why Amazon shopping app also not compatible? (anyone cfm? 8beta.)
thks, yup sideloaded.Just sideload can work... get the apk from apkmirror or similar site, and install directly.
Do your phones have printing on the back of the phone or only the Mi logo? Like this one
(on local backup).
Any idea which is the folder for this backup? (Wanna transfer to another phone, without using mi services.)
Thks. Acty I rooted which wiped out everything, but luckily this local backup is in the external card, and can be restored.![]()
put the backup folder in this sequence in the new phone. create the folder, Backup and/or Allbackup, if cant find in the new phone.
But curious why many apps are incompatible?, can't be already standard resolution.
List of incompatible apps on miMax:
1) mytransport
2) Amazon
3) uniqlo
4)
5)
Add on popular apps
ya ended alrdymaybe wait for oct then
mine auto backup to SD card ..so when i change phone or format phone just transfer the SD card den can restore liao(on local backup).
