China Tablets to recommend
Computeron
Have you tried it without the tempered glass yet?
didn't...have to remove my temper glass sia...
in android os still not so bad..
but in win10 os... 1/3 of the screen is not responsive... most likely is os problem.
i1magic
Was thinking whether to get a tablet or Xiaomi Notebook Air.
Anybody has that dilemma too?
Audiology93
Sold my China windows tablet and ordered the mi notebook air. Reasons being better build, more reliable OS, better wireless connection and basically mi notebook air make me feel more at ease. No need scared this scared that or when the tablet will spoil. Also, most China windows tablet have this issue with the keyboard that when you try to swipe down on the touchpad from the top, it will minimise all windows(it's a windows gestures but cant be disabled unless you apply some fix). If really budget constraints then no choice have to go for whichever that is cheaper.
Sent from Xiaomi MI 5 using GAGT
marandaz
mine is w/o.
then urs more worth.
Care to share your brief review of the Chuwi HiBook Pro?
> How long does your battery last with full charge?
> Are the app loading on Android & windows snappy?
> What are the cons according to your opinion?
Kum Sia
Computeron
Kum Sia
This table like phone like that. If u use extensively, one day charge one time.
I came from iPad mini 2. Compare to this. Hibook pro win on the screen size n nothing else.
Scrolling of Fb n web not that smooth, type words. Sometimes cannot detect so called not responsive. Maybe becuz of my glass protector.
Screen on too long will get hot like phone. IPad mini will only get warm.
But well for $300 for a China brand. Mai hiam... Cuz i use for watch movies n light surfing at night only.
If u r using on the go. Carry it with u as much as phone. Better don't get.
Sent from Xiaomi REDMI NOTE 3 using GAGT
marandaz
Kum Sia...
How is the build quality by the way?
Just pressed the buy button. Hopefully, not a lemon set....
yusoffb01
Kum Sia
A lot of online reviews are fake. Here is actual state of the tablet:
Cons: not laminated screen
Widespread battery issue - drains while off or dead in a few months
Insufficient cooling causing overheating
Cannot wake up after deep sleep
Bliescreen if u enable windows update
Bootloop if u enable windows update
Ghost touches on screen
SD card problem
Cannot use WiFi and Bluetooth at the same time
Poor WiFi reception
Batch after April 2016 use lower quality emmc memory to cut cost. Actual speed is 20mbps instead of 140mbps in earlier batches. This really puts me off.
To me, that's too many cons so, I went for cube iwork8. Other than relatively poor 3.5h battery life it doesn't face any of the problems above
For scrolling on web browsing, use Firefox you won't face any problems because it use less resources. YouTube 4k plays fine
Computeron
SD card problem
Poor WiFi reception
WA.. Urs sounds serious. Urs is first batch?
i1magic
You bought which version? The 12" or 13.3" version?
So can I say that even surfing on Xiaomi Notebook Air feels better than on any of the tablet that you have so far?
Have you receive the Xiaomi Notebook Air yet? Which channel did you use to buy?
Audiology93
12.5. super smooth. None of the China tablet even come close to it. Most China tablet are running on 1066mhz ram and the sluggish performance is very obvious.
I got it from lazada.
yusoffb01
yusoffb01
Just full charge it and you could either switch it off or standby mode
If standby overnight <8% loss is OK
If switch off 1% for 1 week is good
For some people have their Asus or xiaomi windows tablet lose more than 10% overnight and that's bad. I've even read chuwi lose a large % even when switched off
If yours not affected then good for you
i1magic
Can you see whether can the RAM for 12.5" be upgraded to 8GB? I was calculating that if I were to get the 13.3" version, it is about $200 more and I get :
1. 8GB RAM (instead of 4GB)
2. Faster processor
3. Nvidia GTX 940M graphic
4. SSD 256GB (instead of 128GB)
5. Additional USB port
6. Slightly bigger screen
Does it seems worth it to get the 13.3" instead?
