Won Exchange Rate
luei74
http://rainieis.tw/blog/post/30941557-%5B%E9%9F%93%E5%9C%8B%5D-%E9%A6%96%E7%88%BE-seoul-%7C-%E6%B0%91%E9%96%93%E6%8F%9B%E9%8C%A2%E6%89%80-%E7%BE%8E%E9%87%91%E6%8F%9B%E9%8C%A2%E8%81%B0%E6%98%8E
Started to do some home work for my Nov Trip....the famous ex opp Chinese embassy
Anyone will be there or currently there please kindly update the rate... thks
j0sey86
i dont think the rate will go up.. but u all can try go myeongdong change? i see previous comments that the rate seems better in myongdong..
poonyq
Just as I saw 800 at Raffles... -*cross fingers*
https://cashchanger.co
registeredname
i just change with this bro over the weekend, friendly and came all the way to find me.
very helpful, thumbs up.
vouch for his good character, better change more won before it goes down further.
waited from 830 to now, 804.. :s22:
Thanks bro! I am currently back in Seoul. I will be going back to Singapore on 21 December to attend another wedding and I will bring another batch of KRW to change in SG again so those going Korea next year can change with me, it'll definitely be slightly better than moneychangers ^^
michteo1907
Hello! Thks for sharing these! However I'm having difficulty determining the location of the money changer on the map. May I know which is the nearest exit from myeongdong station to take? thks so much!!
luei74
Can click on the link for details. Nearest should be Myeongdong station exit 5.
Please kindly update the rate when u r there, thanks :)
michteo1907
Thanks a million Luei!
I'll definitely do that if I get to the money changer when I'm there next week!
michteo1907
Depends how much you are changing that you can feel the difference. Now is around $125 for 100,000 krw.
Saw the best rate displayed at one of the money changer to be 810 at myeongdong. Most others are 805 & a couple below 800.
