Xiaomi Mi Max
eDisFieD
After reading the thread, I'm kind of confused by the ROM and Version. I'm currently this:
And now I'm prompted to update to this:
Should I? What are the potential problem I will be foreseeing? Appreciate your kind advices :)
FinchGuy
PC cannot recognise Mi Max when connected via cable so can view internal memory or SD card. Need special driver? Tried Mi PC Suite but that didn't work. TIA.
Oinkize
Did you pull down notification bar to select mtp?
happily1986
Anybody have problems forcing the phone to accept two simcards plus the micro sdcard together?
I have already burnt off the epoxy backing of the nano sim but it just won't go in.
What I simply don't understand is why the phone indicates as a matter of fact that it supposedly can accept two simcards plus the micro sdcard but almost everyone is resorting to hacking their nano simcard to force them in.
Nakedtoes
Where got everyone hacking? Xiaomi also nv state 2 sim and microsd.. They already said hybrid slots. If so difficult dun use the phone lor.
jace88
I don't think they ever advertise it as such... it's always been either two sims or one + microSD.
That being said I think there's definitely a market for someone in SLS to specialise in this service for customers! I want it for my MiMax or my S7 Edge but not game enough to do it given the sim card I want to do to is not local and would be impossible to replace easily.
kelvinti
Ok folks,
Played enough with my Mi Max gold.
You know what I mean and you know what to do. Kekeke.
All are welcome.. :)
davekwb
Hi,
I am new here. Wanted to get a work phone. Just wondering how to differentiate local set and China set?
Where to get cheaper local set? Challenger is selling 349.
Thx
