China Tablets to recommend
Computeron
I noticed after flashing to remix OS on my hibook pro, batt life is better.
Now I finding an app to dim my screen. At tablet 0% brightness, is still very bright in the dark. Those apps I downloaded from play store like not remix compatible
marandaz
I agree.
On Andriod, I set my brightness to 0%. And I still find it bright.
However, on Windows I set my brightness to 50%
Teo Ming Ern
When you plug in to charge, does the metal chassis leak current? Do you get a shock when you touch the metal frame? Cos I always get a shock when I used to use China tablets... that's why I refrain from buying them now.
Mr. Bushido
Hi all. Am considering getting the Chuwi Hibook Pro. But I wanna check it out in person before taking the plunge. Any shops at Sim Lim square got a demo unit?
Bought a Teclast X16 Plus not too long ago. Got burnt :s22:
-Very poor screen, non-laminated
-Extremely heavy
-Very poor performance
Anybody can advise whether the Chuwi Hibook Pro is for me? Saw videos online and read reviews saying that the screen is very good, since its laminated. What about performance? Seems to be about the same as my Teclast X16 Plus, since it is using the same Intel Z8350 Chipset, though the Chuwi Hibook Pro has 2 more GB of RAM.
Computeron
-Extremely heavy
the screen is beautiful n bright even at 0%. I'm using 0% in day time. Text r crisp n sharp.
Abit heavy, maybe I came from iPad mini and I had a book case on my hibook pro.
Performance still decent for me as I only used for movies n browsing
Sent from Xiaomi REDMI NOTE 3 using GAGT
yusoffb01
Use grounded 3 pin charger
marandaz
FINAL Review of Chuwi Hibook Pro
Background
> Bought it for SGD$334.62 (After $30 Promo code)from Lazada.sg on 28 Sept.
  • Disclaimer: No sponsorship or whatsoever, bought it with own money.
> Received the package (Boxes are nicely bubble wrapped) on 6th Oct, hence it took them 8 days to deliver it from China-Shezhen.
> The package includes:
  • 1 X Tablet
  • 1 X Keyboard
  • 1 X Charger (Rated at 5V 3A)
  • 1 X USB-C Cable
  • 1 X Very Cheapo 3-pin Travel Adaptor
Appearance, Looks & Feel
> Both Hibook and keyboard have an overall metallic appearance. Certainly does not look, except the logo at the back, like a cheapo China product.
> Both Hibook and keyboard feel solid and sturdy. The back of tablet is metal encased, or at least feels like one, and does NOT flex in when pressure is applied to the middle.
> The bezel that surrounds the screen is a fingerprint magnet (Not surprising). By default, the tablet comes with a screen protector.
> The thickness of the tablet feels right for me. It does not feel thick even if the keyboard is taken into consideration.
> The tablet is locked onto the keyboard by two magnetic clips.
  • The magnets are powerful which meant that it gives a very firm docking;
  • BUT this also meant that it requires much force to undock it. (Tip: Hold the tablet by the top for support while pushing out the tablet through the bottom)
> The tablet itself feels relatively light and balance when holding by its side or Centre-bottom with my right hand.
  • Don't really feel the immediate strain on my wrist when holding it;
  • BUT does feel tiring after holding it for prolonged periods of time (No-brainier);
  • Heat is produce on the left side, hence you may not want to hold the HiBook by this side.
Spec & Benchmark Test
> CPU is Intel Atom Cherry Trail Z8300 64bit Quad Core.
  • Geekbench 4 CPU Score (~7mins to run the test) is 778 & 1701 for Single and Multi Core respectively (Battery saving mode OFF);
  • Geekbench 4 GPU API Score is 4727 (Not in battery saving mode);
  • Max temperature I have gotten is 81 Degree Celsius (Using HWinfo64) in non-aircon environment;
  • *Task done include: Installing programs, downloading programs & playing videos all at the same time;
  • Max temperature is ~75 Degree Celsius for just playing videos in full screen.
> Ram is 4GB DDR3 BUT clocked at 1067MHZ (According to BIOS)
> Main Storage is Toshiba 64GB eMMc.
  • ~44GB of it is partition for Windows and free storage space is ~27GB;
  • ~10GB of it is partition for Android and free storage space is ~9.7GB;
  • Read and Write Speed is on a slow side of 136.7MB/s and 25.93MB/s (Using CrystalDiskMark).
> The OS are Windows 10 Home Edition & Android Version 5.1 Lollipop.
  • Took ~25 Sec to boot up for Windows 10;
  • Took ~35 Sec to boot up for Android;
  • Took ~25 Sec to switch between the OS.
> Screen
  • Max Resolution is 2560 x 1600 (16:10 Aspect Ratio);
  • Screen is beautiful and clear, though I think it is a bit overkill;
  • There is light bleed (Counted 3 spots) at the right side of the screen;
  • Brightness at 50% on Windows and 0% on Android is good for me in indoor.
> Keyboard USB
  • NOT able to detect External WD Element 500GB HDD (LED did light up, but no drive detected);
  • But ABLE to use wireless mouse;
  • Also ABLE to use Sandisk Flair 64GB Thumbdrive. Read and Write Speed is 39.64MB/s and 24.88MB/s respectively.
Sound Quality
> Generated quite a loud sound from its speakers (Located on Bottom-Left-&-Right). But sounds hollow i.e. NO bass at all.
> For the earphone jacked-in, the sound generated is okay. I believe it depends on your App or Program equaliser.
Battery
> Able to charge with Aukey 20,000mAH Power Bank through USB-C. Managed to charge from 18% to 55% in 1.5 hours. I believe a full charge of this power bank should be able to charge the HiBook fully ONCE.
> Charging from the provided charger took about 4 hours to reach from 12% to 100%.
> Able to get ~4.5 hours of battery life from 100% charged to 10% under the following condition:
  • Battery Saver Mode OFF;
  • Set 50% brightness on Windows & 0% brightness on Android;
  • Tasks executed within the 4.5 hours include:
    [#]Downloading and Installing of Programs or Apps (e.g. Open Office, R, Youtube, etc);
    [#]Installing steam and games like Stardew Valley, Prison Architecture & Torchlight 2;
    [#]Playing 3.5 episodes (~1.5 hours)of One Punch Man;
    [#]Streaming Youtube for ~0.5 hours;
    [#]Running Geekbench and CrystalDiskMark;
    [#]Switching between OS;
    [#]Ran the aforementioned games for a short while to see the playability;
    [#]Installed BitDenfender as my Anti-virus software;
    [#]Some of the above stuffs are ran concurrently.
    [#]Wifi is ON, bluetooth is OFF throughout.
> Did not see any significant discharge or saw ~1% discharge when switch off and on it the next day.
Performance: Games and Programs
> Takes >10 sec to open a 100KB excel file on Open Office
> Stardew Valley, Prison Architecture & Torchlight 2 is UNPLAYABLE for me:
  • Even if the graphic setting is set at lowest details and resolution, there is still stuttering at less intense moment of the game;
  • Setting to the lowest resolution leads to annoying sizing due to the 16:10 aspect ratio of the screen.
> Able to play ZSNES (Mario kart) and openTTD SMOOTHLY;
> Playing of 720p One Punch Man (Using VLC) is SMOOTH;
> Surf of website (Using Edge) is generally SMOOTH, but not so for resource intensive website like Facebook especially scrolling down and loading new feeds
> Can't really complain much since the performance is inherently due to the limitation of the CPU.
Other Notable Problems & Issues
> Android can't recognize my micro SD card (Sandisk Ultra SDXC 64GB) formatted in exFAT.
  • Need to format it to FAT32 (-_-") which means that I can't store any files that is >=4GB;
  • Read and Write Speed is on a very slow side of 22MB/s and 12MB/s respectively;
  • Can still use the SD card formatted in exFAT on Windows 10 though.
> Play Store on Android hangs quite frequently.
(Your Mileage May Vary)
yusoffb01
Exfat in android is due to licensing issue.
26MB write seems jialat... Similar to my cube
marandaz
wifi speedtest how arh??
Wifi Speed is (Using Ookla):
Download: ~19.5 Mbps
Upload: ~1.1 Mbps
Testing condition: 3-4m away from my router with a TV blocking in between.
I did not test my Wifi using other devices, hence I can't say whether the above speed is limited by my ISP, Router or HiBook
Using Starhub MaxOnline Premium (Still on cable):
Max Download: 50 Mbps
Max Upload: 2 Mbps
Router is Cisco Model DPC3925
Real Life Usage:
> Able to hit download speed of 2-3 MB/s on Steam
> Able to stream 720p and 1080p Youtube videos on Andriod App or on Edge in Windows 10 smoothly.
> I find that videos on 1080p is a tad less smooth than on 720p.I believe this is not due to the wifi but the graphic processor. But generally, don't find any stuttering.
lido410
My Cube iWork 10 Ultimate/Flagship just arrived. For now, everything seems pretty good. Screen is clear and good in contrast(1200p). The air gap between the glass and the display underneath it is very tiny! Might be even tinier than my old iPad Air 1. One of the best screen on a china tablet for now, but that is until the launch of the HiBook Pro which has 2k OGS screen. Free RAM on android side is 3.3GB :eek:. Have not setup Windows yet since I mainly use it on android. Chris from TechTablets has a few videos on the tablet. I bought the keyboard dock as well.
Hi bro is flagship and ultimate the same model I can't find ultimate on taobo all flagship.Tks
Computeron
I JUST realised.. hibook pro brightness can be lowered in window OS…
andriod os 0% brightness (still very bright) = windows OS 30% brightness
wawa33
I just gotten the Teclast X98 plus II & tbook10.
The quality of Tbook 10 is very premium, solid build.
X98 plus II a bit plastic feel exactly looks like an ipad.
Both is good I feel except that X98 plus II has higher resolution.
Hi bro, intend to get either one of which that u have bought recently. Mainly use for upload project photo/images, watching movies and surfing internet.
Mind to share the pros and cons of each device when it is running in Andriod platform and window 10 system.
TIA
watzup_ken
Upload: ~1.1 Mbps
Max Upload: 2 Mbps
Real Life Usage:
May be you can consider getting one of those USB to LAN converter to boost the speed of the internet connection. It should be better than 1.1 Mbps for upload.
