The Perfume Thread
m/mink
London is £178 iirc, cheaper than here by $100, can vat refund somemore.
FrozenClay
SOTD
m/mink
Just curious. Do you guys only SotD, or there's a different SotN as well if you come home and go out again.
darren89
I tried the new Versace Dylan Blue , smells pretty good, somehow similar to Eros but alittle stronger
m/mink
I normally don't as most of my perfumes last til nighttime.
That's good.
I tend to use lighter green/citrus base frags for day (MFK universalis, AdP Blu Mediterraneo series, Mugler cologne etc) and they are almost gone by evening.
m/mink
Anyone knows where can I try/buy this locally?
Rasasi La Yuqawam's a clone perfume that is similar to TF Tuscan Leather.
messi7
Guys, is Bvlgari Aqva Pour Homme or Issey Miyake L'Eau d'Issey Pour Homme suitable for work?
which is more lasting too? Thanks
FrozenClay
I've only tested the Bvlgari but it seems too casual for me. I used to have the Issey Miyake and wear it for work. Lasts quite long on my skin. Could go full day of work and still catch whiffs of it.
If you are wearing smart casual/semi-formal i'd go with Issey Miyake otherwise with Bvlgari. At the end of the day choose the one you like.
messi7
Hi Frozenclay, thanks for your reply.. i think i will go for Issey Miyake :)
starlike
depends on work settings.. u work in office environment? den i think abit too casual imo.
gascon7
Online. Theres a Rasasi Hawas which some compare to Chanel Allure Homme Sport Eau Extreme.
m/mink
Very beautiful bottle. Is this the one?
Yes, that is the one. Lubin Idole.
I love the bottle, a small percentage of my perfumes, I buy for the bottle rather than perfume itself. But Lubin Idole is both. :s13:
Thanks! Was hoping to sniff it first before buying.
There are a lot of TF Tuscan Leather clones out there, expensive/cheap, good/mediocre.
I came across this particular perfume from Italy which is a better clone than TFTL, nicer bottle than TF, cheaper than TF, but didn't buy since it was quite expensive (€250) and I didn't test it extensively.
http://shop.themerchantofvenice.it/eu/liberty.html
