renfred89
- Nov 11, 2007
Hey thanks for the reply. Another question. For my connection from Aztech router to Asus router (using it in Access Point mode) should I connect via LAN port of my Aztech router to the WAN port of my Asus router or LAN port of my Aztech router to the LAN port of the Asus router? If I were to use the latter set up (LAN -> LAN), will I still be able to hook up my PC to another LAN port of the Asus router for Internet connection?
you cannot use asus in access point mode if you connect LAN to LAN.
Asuswrt will only detect the WAN port if you intend to set the system into access point mode. Meaning, once your asus router is set to access point mode, there Aztech LAN should connect to asus WAN..
From this set up, asus allows you to make full use of your 4 lan ports.
This is an asuswrt firmware feature, not applicable to all routers..
