China Tablets to recommend
yusoffb01
May be you can consider getting one of those USB to LAN converter to boost the speed of the internet connection. It should be better than 1.1 Mbps for upload.
The problem is that he is using cable broadband so upload sucks. It is capable of at least 20mbps
ffgghh
any long usb type c cable that works for chuwi hibook pro?
brought a 1.5m type c cannot use on chuwi sia
Computeron
Any hibooknpro user experience screen dim then normal... then after a while will dim... athen awhile bright again? I alrêdy off my auto brightness. Just noticed this after my windows update.
Audiology93
I believe it's the "auto dimming" feature setting in. Had this issue with my lenovo yoga 2 10.1. the brightness will go up when majority of the content is white and brightness will go down when majority of the content is black or dark coloured. Very irritating when using at night. You can try changing the settings and see if it works for u.
http://windows.wonderhowto.com/how-to/disable-adaptive-brightness-windows-10-for-maximum-screen-brightness-0163440/
Sent from Xiaomi REDMI NOTE 2 using GAGT
Computeron
http://windows.wonderhowto.com/how-...ows-10-for-maximum-screen-brightness-0163440/
ITS OFF WOR… still dimming n brighter itself
marandaz
1. This auto dimming happens on Windows right?
2. You already switched off the adapative dimming through Windows settings right?
3. If #1 & #2 were "Yes", then go to your Intel Graphic setting (can be found on your icons), then go to "Power" option, disable the second one that has something to do with adaptive display
Computeron
Sorry I noob to Windows... Where sia?
Sent from Xiaomi REDMI NOTE 3 using GAGT
vofzxy
LOL the more techtablet i read the more i can't decide which tablets to get ><"
i just need one for everyday use, read books, i can't game on windows for sure,
i dont hardcore game on android anyway...
but i guess the apps on android is much handier then windows store right?
i don't even know what does the windows store sell LOL
yusoffb01
Better get android if u don't have a tablet
Kegler
I find china tablet mostly battery doesnt last long.... Anyone has any way to improve it?
