LG V20
Vulpix
Moderator
Moderator
Lol the tempered glass available at the shops now all kns fitting one. I just warn you all first. They will all lift one because it stretch to the curved areas of the screen.
Recommendation: Don't buy if you not sure of the brand.
Kcusts
What about the your one from spigen? It fits perfectly?
Vulpix
Moderator
Moderator
Mine is from Nillkin. I will be trying it out later but preliminary sizing shows it will only cover the flat screen part.
xiaorazor
when u paste yours liao remember post pic, i want see how much it cover?
Audiology93
knn u all is damn poison. keep posting photos of it :s13::s13::s13:
now don't know want to choose black or silver :s12:
tkdboi
Sent from Motorola XT1650 using GAGT
Vulpix
Moderator
Moderator
Ok, tested the Nillkin, seems to be cut ok. One corner dunno why slight lifting. Gonna readjust but this one definitely better cut.
Vulpix
Moderator
Moderator
Oh my god why is the auto brightness fighting with me wtf
Archyz89
Anyone have any idea $998 is 64gb or 32gb ?
Nevermind, $998,64gb is Starhub/M1/Singtel and LG retail store & only on 5th November 2016. Outside shop sell cheaper than the original store.
anirudhks
so any one recomend TG ?the pre installed plastic one is very fingerprint magnt , vulpix bro say other glass lift up :( , so which one to buy ?
Vulpix
Moderator
Moderator
For now I recommend the Nillkin, but please, before you paste it on measure the height. And make sure cover correctly. I had to redo mine a bit.
