New MacBooks and Recommendations
putrasocool
Hi...
New MacBook Pros were released hours ago...
If u c the price point, quite high...
Maxed out 15 inch is already $4000+
I need a new laptop for video editing purposes... Mainly using Premiere Pro. Will sometimes use FCPX for faster, simpler editing.
The 15 inch is 1.8kg while the 13 is 1.4kg.
The 15 inch spots an AMD GPU, up to 4GB GDDR5.
I heard the AMD GPU dun work well with Premiere Pro. Is that true?
So, for me, which mac should pick...?
Reignxy
It listed for $3948 on their website for the max out 15 inch version. Still thinking wanna upgrade or not.
*adiBOY
That's not the max out model. That's only the 2nd better base model. If you try to max out the specs, it will be more than 5k.
ckling
the old mbp also increase price?
last time 2688 now 2788 ?
*adiBOY
The way I read is the $2788 is the new base model with 2 thunderbolt ports, but without the touch bar.
The new model without Touch Bar and 2 ThunderPort 3 is only available for 13" which starts at $2188.
He is referring to the 2015 15" MacBook which was starting at $2688. Now apple has increase it to $2788.
Errz
wonder if i should get the 2.9GHz Processor ,512 GB Storage and upgrade to 16GB Ram.
my mac mini (late 2012) 2.3GHz intel Core i7 with SSD is connected to living room TV due to no study room.
mainly surfing, video , editing of photos.
duhduhduh
It seems like the new MBP is targetted more for working professionals or those who really needs it.
Still rmb the times that Macbooks was only for art/media/video students. Then it became a mainstream laptop and now Apple is differentiating it between Macbook and Macbook Pro
mentosonline
I considered the same option as you, but then the base 15" model with storage upgraded to 512gb is only a bit more... still thinking about it.
infinity2014
anyone knows if more RAM speed up the process or not? e.g. last time I bought iMac with 12GB but the speed still so so .... will it be like android regardless of how many ram also the same ....
putrasocool
I was thinking to get the 15 inch for my school projects... Taking diploma and requires a lot editing of videos and photos as thats my major.
Price is on the high side...
Which is perfect??
*adiBOY
Which is perfect??
I would suggest you go for the 2015 MacBook Pro. It is more than capable enough to complete your task.
hereiam7788
yup. Very surprised that apple is still selling 2015 MacBook pro and again increases the price. Maybe it is due to the drop in sgd against usd.
JuveZzZ
Just to check can we diy upgrade the ssd or ram? For the mbp 13 inches?
