Exchange Rate
calkel20
how to lose on commission. e exchg rate i base on Arcade rate, so no commission involve.
In taiwan, at most NTD30 admin fee if chg in airport?
Am i right? correct me if im wrong
Yes and Yes. Not forgetting now it's floating as you have USD in hand.
And it can change anytime.
No harm trying.
IcYFl4mEz
Not v worth if u changing small amt. Large amount like few k to tens den worth
k1180n
Thank you for the info. I will change USD in SG and change to TWD at taoyuan airport. As of now, I could get 22.44 rate. I think my calculations should be correct.
S$1.39 - US$1
US$1 - TWD 31.205
So 31.205/1.39 = 22.44
I'll be there this Friday so don't think the exchange will fluctuate much.
calkel20
S$1.39 - US$1
US$1 - TWD 31.205
Should be.
Sounds good to still get 22.44 rates.
sunht
S$1.39 - US$1
US$1 - TWD 31.205
Is it confirmed that the rate used at airport same as their website one?
twosix
S$1.39 - US$1
US$1 - TWD 31.205
This is innovative.
IcYFl4mEz
what time does the airport money changer close? if reach there 11+pm , still open ma ?
calkel20
Supposedly be 24/7. So u gotta change once you see it.
The ones at arrival may be closed, so you have to get to departure area.
calkel20
I thought I would lose out after making 2 exchange. Surprisingly not. Maybe USD higher value than SGD. not sure after the elections though.
I share the same sentiment.
Lastly if so good, then i may just go dbs and change since i have quite a bit of ntd at this moment of time.
All this exchange rates are floating thus like what i have said before some times arcade is good, sometimes not.
No fixed one direction.
