The Hair Thread - Part 4
voltshin
Been using by Vilian gold digger and mattehed extra. Is there any product similiar to these?
Would like to try other.
Most impt must be easy to wash.
Thanks!
gaoxing84
Thanks!
can try morris motley or uevo grey
morris moltey high hold, easy to wash and acts as a treatment product
uevo grey more of fixated hold and also easy to wash, way lighter than all the products named on top
voltshin
Morris Moltey too ex for daily use.
Will try out uevo grey.
Thank you!
Beta_Tester
Deluxe Member
Now got 11% promo. Later I see got what to hoot. My stuff running out.
Morris smell good bo? Lol
djoker
BB60 w/ free shipping at 50% off ($14.50) at Panic Room.
Don't say good things never share.
Sent from LGE LG-H815 using GAGT
Thanks for the lobang bro. hooted a BB90 liao coz BB90 also got sale.
Tried for first time and it didnt work leh. Damn freakin dry (ok I expected this) and not much hold. I applied on dry hair finger-combed (didnt use comb coz it probsvly will be hard to pull comb through) and also used blowdryer after using
pre-styler as per normal. Mm chrome, odouds wb all work for me with this method but for some reason bb90 doesnt. Anyone has any other suggestions on how to use bb90? The jar says use on towel-dry hair. Maybe i should try that next time..
A bit about my hair profile. Quite thick and straight. And i style standard side part aka classic businessman look (not pompadour).
x3dnd3x
My left over Uevo Grey should be able to last for another 1 month before i hoot 1 batch from GX. I still contemplating between GD or use back Uevo Grey.
:sad:
gaoxing84
how good is it?
currently using byvilian silverfox, very hard to wash off
Bb60 is Good for long hair.
If you want easy wash off and lightweight, try uevo green.
You want the best. Morris motley Chrome.
Assuming you want Shine.
gaoxing84
:sad:
Better hoot now before today ends!
Uevo la. Haha I everyday use uevo now haha
gaoxing84
Thanks for the lobang bro. hooted it liao.
Use with towel dry hair if you want defined look.
I use the same method for all my wax. Bb90 need to work in fast.
jayz89
Hmm i have short hair, whats the diff between mm chrome and the other version?
gaoxing84
Pls don't buy bb90. It's more of a cream. For long hair.
Like surfer kind.
Chrome is shiny. The other one is matte
jayz89
Like surfer kind.
Yea i was looking at bb60 just now.
Then again, i guess i will buy off ur website for the matte ver since there is the 11% discount
