Did anyone of you manage to install TWRP and root your phone?
Is it worth to get a mi 5 32gb export set at $350 now ?
I got mine at <$338. So somewhere there...
But preloved ,2nd hand leh
yes i did.
Currently running CM13 on my rooted Mi5.
TWRP can be a bit cranky at times and refuse to response... sometimes need to reboot a few times to get it working the way it should.
But when it work, it is a breeze
CM 13 supports 4G + 3G ?yes i did.
Ok but is the phone worth it ?
$300+ for sd820 device, go where to find?
If want the latest sd821 and no budget constraint, get the mi5s, mi note2 or overpriced mi mix. Simple.
Is preloved at $300 worth? Export set and user used for like a month plus
receiving 8.1.2.0 for global rom update, updating now!
Not worth. Rather buy brand new at <$338 after shopback and lazada discount codes.
Thanks. How much is the discount and what's the promo code?
