Xiaomi Mi 5!
overcrash
Did anyone of you manage to install TWRP and root your phone?
yes i did.
Currently running CM13 on my rooted Mi5.
TWRP can be a bit cranky at times and refuse to response... sometimes need to reboot a few times to get it working the way it should.
But when it work, it is a breeze
ftpofmpo
yes i did.
Which method did you use to flash twrp and were you on miui 7 or 8? I managed to unlock the bootloader but can't flash twrp using the method documented on en.miui.com/thread-309596-1-1.html
Thanks
Kyrogex
yes i did.
CM 13 supports 4G + 3G ?
Sent from OnePlus ONE A2003 using GAGT
Oinkize
But preloved ,2nd hand leh
Preloved somemore? Mine brandnew...
Try to find from lazada, go sign up for a shopback account at shopback.sg/hwz for more rebates then see if there are any lazada coupons to use..
maxlovely
Is preloved at $300 worth? Export set and user used for like a month plus
Definitely worth it. if you compare with mi5s, people are complaining the mi5s fingerprinter sensor, very inaccurate, took many times to unlock the phone.
mi5 also has IR blaster, working Android pay.
Oinkize
Thanks. How much is the discount and what's the promo code?
Sign up for shopback account at shopback.sg/hwz then use shopback to direct you to lazada. Choose what you want to buy and use either codes.
CIRCLESLAZ $30 off min $300 spent until 10 November 2016 for existing customer CIRCLESNEW $35 off min $300 spent until 10 November 2016 for new customer
sydney16
Thanks !
Anyway the one I'm looking at is 32gb model. It should be the snapdragon 820 but hexa core version. Wondering if it's going to be a flagship worthy experience or its just going to be like my current iphone plus model ?
I read a lot of good reviews about mi5 but most are using the 64gb variant for reviewing.
