HWZ GoPro users
jack27
Hi, Planning to get gimbal for my Hero 5 too.. may I know which model are you using & where to get + price? TIA
any recommendation for gopro skins? or gopro frame without having to attach it to a mount? need to use with my gimbal..
radzkal
Im using feiyu tech spg. Compatible with smartphones like iPhone 7 plus as well as action cameras like gopro because it uses a flat clamp so not limited to a specific camera. I think it should fit gopro hero 5 (i got a 3+). Got if off aliexpress. Blazing fast DHL shipping. Received it within 24 hrs. US$259 after US$20 off discount. It's about $360 sgd.
hungzz
does anyone have any recommendations for gopro gimbals besde feiyu tech? karma grip so long havent come yet
pioneer888
hi guys. I just bought my gopro 5 at 544 from lazada singles sales. The site indicate that it provide international warranty but I don't see any warranty card in my packaging . Is that normal? How do I register for warranty then ?
FlyingOhm
You c an do it online - register your GoPro and enter serial number and place of purchase
a few questions here.
1) where can i get the cheapest or decent deal on GoPro hero 5 black? How much?
2) difference between local set vs international set? How do I tell one from another when I buy? Warranty wise any difference, I heard some set does not come with warranty?
3) Is there any concern if i pick between local vs international set?
4)Any recommendation on where to get accessories?In terms of cheap or....
5) I'm going for an oversea trip, normal traveling, skating, skiing, etc. Can you recommend some accessories that you think will be useful? Where to get? Some links would be good!
6)Apart from accessories for traveling, which other accessories have you found to be your favorite?
Thanks!
flekzout
1) where can i get the cheapest or decent deal on GoPro hero 5 black? How much? - changi DutyFreeShop, or you wait for the deal in QOO10 or maybe lazada. search around because price varies all the time, do your own due dilligence.
2) difference between local set vs international set? How do I tell one from another when I buy? Warranty wise any difference, I heard some set does not come with warranty? - doesnt make any difference, but get the international if possible. main point is still the same only 1 year warranty.
3) Is there any concern if i pick between local vs international set? - no.
4)Any recommendation on where to get accessories?In terms of cheap or.... - try use carousell, many ppl selling there.
5) I'm going for an oversea trip, normal traveling, skating, skiing, etc. Can you recommend some accessories that you think will be useful? Where to get? Some links would be good! - Just get the 3 way tripod, chest and head strap. no need to buy the original, just buy from carousell.
6)Apart from accessories for traveling, which other accessories have you found to be your favorite? - it depends on your sports but 3 above good enough, dont push too hard, you are not professional sports player. have fun rather than adding more stress.
Thanks!
answer above.
Collectible
anybody knows which capitalland mall have stocks for the hero 5 waterproof casing?
taytehni
managed to get the gopro hero 5 at 458sgd including $20 worth of filler items, therefore the amount spend on the gopro is approx 440.
bentonfraser_4ever
Have you guys heard of the REVL Arc cam? I actually was impressed by it after my camp mate told me in ICT that he bought shares in that company (he studied in US last time so that was his uni friend i think). I went to google it and watch the vids, so i bought it through their crowdfunding campaign.
It's supposed to be ready by December from their R&D facility so.. crossing my fingers hope it will be gd la! Otherwise.. $800 gone just like that :(
But check out their specs. Sound really good.
Norman Chan
For the GoPro 5 Black, what are the specifications for the aperture and focus length for both video and photo taking?
FlyingOhm
It's really nice but the price don't seem attractive
